Create Jira Issue in Confluence:The required field xxx is not available in this dialog
Ollie Guan
I need in the Confluence directly Create Jira Issue, but the system prompt is as follows
These fields are created when necessary, how to solve?
Madhusudhan Matrubai
Ollie,
Not sure if you have already realized this by now.
Looking at the error msg the field "PR Type" appears to be a select list custom field and that's not supported yet - https://jira.atlassian.com/browse/CONF-32906
So you will have to vote on the JIRA and wait endlessly until Atlassian implements it.
Atleast you don't have to upgrade for this reason.
BTW as a workaround remove the field as mandatory and instead put a validation in your workflow during transition.
Alejandro Conde Carrillo
January 8, 2015
Which version of Confluence are you using? I believe you could be hitting this known issue: https://jira.atlassian.com/browse/CONF-23424. The issue was fixed in Confluence 5.5.
Ollie Guan
Hi Alex, My Confluence version is V5.6.5,and my Jira Version is V5.1.1 Whether caused by two versions do not match Thanks!
