Create manageable milestones for project for tracking at the Leadership level
Smitha Joseph
How can I create manageable milestones for my project for tracking at the Leadership level. Need milestones to publish to Leadership for management and tracking purposes.
Benjamin Jurg July 2, 2024
There is a new Atlassian feature in beta called goals which might be the thing you are looking for. We are piloting that feature right now.
Another solution would be to have a dedicated page for each milestone and use the combination of page property and page property report where the milestone page contains a page property table with fields like name of the milestone, date of the milestone and status (on track or not).
Finally, another option is to have a specific Jira project for the milestones where you can maintain the status tracking at that specific Jira issue.
Smitha Joseph
Thank you @Benjamin Jurg for your answer. Would there be a video which I can refer to for using this approach as it would be easier to try.
Benjamin Jurg July 5, 2024
Which of the options are you most interested in?
Here my 2 cents considering the options:
Goals:
+ Dedicated for this purpose.
- New/beta thus unproven and has some beta-bugs.
Confluence pages:
+ Allows free format adding specific details to each milestone.
- Status tracking of the milestones is all manual.
Jira project:
+ Allows advanced status tracking.
- Adding more details is not that comfortable.
Depending on the organization style (some companies are very strongly Jira oriented, others more confluence oriented) that could influence the decision making too.
Smitha Joseph
@Benjamin Jurg The approach: "Another solution would be to have a dedicated page for each milestone and use the combination of page property and page property report where the milestone page contains a page property table with fields like name of the milestone, date of the milestone and status (on track or not)." sounds good and I was looking for more insight to follow this approach.
Benjamin Jurg July 8, 2024
I use that combination a lot, personally more of a Confluence oriented guy ;).
Here a very informative article by Atlassian: https://support.atlassian.com/confluence-cloud/docs/insert-the-page-properties-macro/.
Also a very nice youtube movie: https://www.youtube.com/watch?v=OiJ43YlminU
Hope it helps.
