Document Control in Atlassian Products
Rav
February 27, 2015
Three questions. (1) Does Atlassian have a document control solution built into your product line? Or is it able to be purchased. (2) Do you know of integration of Atlassian with ANY other open source document control product? (3) Is there any documentation on how to interface with the APIs you mentioned? Thanks.
Elizabeth
AppFusions' has developed, sustained, and supported packaged integrations between Confluence/JIRA and Alfresco, Dropbox, Box, Google Drive, and OneDrive (Office365) for years now (starting July 2010).
Email info@appfusions.com for evaluation licenses.
Timothy
February 28, 2015
If you make the pages in Confluence the document itself, then yes , Confluence's permission schemes should be good enough.
Not sure about this. You need to search more on this.
You can either develop an add on using the Atlassian SDK or use the REST API provided by Confluence
