Hi guys,
I have an IFTTT macro to "Create Jira Issue" and the JSON is wrapped in a NOFORMAT macro. I have custom Jira fields of type "Text Field (multi-line)". In my form, when a user submits an entry using double quotes " then the form throws an error. Problem is that I cannot seem to be able to escape this character. I have tried the following:
[entry.IHRisk1.escapeJSON]
IHRisk1 is a field of type "TextArea" in Confiform.
If I pass double quotes into the system field summary or description, I have no issues, but that is not what I want in terms of behaviour of the form.
Surely Confiform should be able to escape characters sent to custom fields in Jira.
Regards.
Stuart.
p.s. I did look at the following link from Alex but this did not work
Hi guys I have solved this, not sure why I did not think of this before !!!!! Solved using virtual function replaceWith. So:
[entry.IHRisk1.replaceWith(",').escapeJSON]
Why this is necessary? Could you share WHERE the quotes are not properly scaped with this "escapeJSON" function?
Are you talking about Velocity templating and setting the local field from a ConfiForms field?
Hi
Where does NOT ConfiForms escape the double quotes for you correctly?
Using the following construction does not work for you?
May I see a complete configuration for the JSON mapping that does not work for you?
Alex
