Iam trying to replace the URL in Space using CLI .
Approach 1:
./confluence.sh --action storePage --space "zconfluencecliTarget" --title "This is title 1" --findReplace "'http://testpage:8080':'http://confluence:8080'"
In this case i could not see any change in the page
Approach 2:
./confluence.sh --action modifyPage --id 105219716 --findReplace "'http://testpage:8080':'http://confluence:8080'"
Here the URL gets replaced to //testpage://testpage:8080
Could any one please help in undestanding what is going on wrong in here .
Also is there a way to search replace a URL in entire Space using CLI rather than doing it for title.
Thanks in advance,
Aravind
Please try using: "'http://testpage:8080':'http://confluence:8080',"
It is an quoting oddity that I would like to fix.
Thanks for the reply ,
Below is my confluence content :
Test page
Test page
Test page
Test page
Command:./confluence.sh --action storePage --space "zconfluencecliTarget" --title "This is title 1" --findReplace "'http://testpage:8080':'http://confluence:8080',"
Page updated: 'This is title 1'. Page has id: 103229632
After firing the commands also contents remains same.
Also is there a way to update the entire Space or all the occurences in the application using CLI ?
Sorry, I should have tested it first. Even I get confused by the workaround :(. Use the following - I have put in some extra spaces so it is readable here. The inner single quotes had to be doubled:
--findReplace " ' ''http://confluence:8080'':''http://testpage:8080'' ' "
Thy this?
--action modifyPage --id 12345678 --findReplace "xxx:yyy"
Thanks for the replay m
I tried ./confluence.sh --action modifyPage --id 105219716 --findReplace "'http://testpage:8080':'http://confluence:8080',"
In this case the"http://testpage:8080" gets replaced to " //testpage://testpage:8080"
