First accesss problem
Robson Garcia June 24, 2021
Hi. I'm having issues with some users accessing confluence for the first time.
I'm getting "you are almost there" error message It looks like our database is taking a little longer than usual to sync up. Wait a few moments then try again. if you continue to see this error, raise a support request".
can you help me?
Hyrum Steffensen _Appfire_
June 24, 2021
Hello Robson,
Please post the following:
  • A screenshot of your database configuration (remove any sensitive information).
  • Any errors you see in the Jira system logs found at <JIRA_HOME>/logs
Hyrum
Hello Hyrum! Thanks for your answer.
I have no access to this information. I have only the user message that they are trying to access. That user is from safari browser and is her first access.
June 24, 2021
Hello Robson!
I would take this up with your Confluence administrator. There seems to be something going on behind the scenes.
Hyrum
Robson Garcia June 28, 2021
Hi Hyrum, I had talked to Administrator and I solved it.
thank you a lot.
Regards.
Robson
June 28, 2021
Sure thing, Robson! Hope you are having a great day!
Hyrum
