Forge - is there way to combine two modules inside a single app
Murugan September 27, 2021
example:
defining both contentAction and contentByLineItem in the same app like below
Shannon S
September 29, 2021
Hi Murugan,
Thanks for contacting us on Atlassian Community! We're primarily end-users here, so your question would be better suited to the Atlassian Developer Community.
I recommend you try your question there. Best of luck!
Take care,
Shannon
Murugan September 29, 2021
thank you
