Formating issue when migrating mediawiki to confluence using Universal Wiki Converter
Raju KC
February 26, 2013
For EX:
Underline word in mediawiki is displayed with tag.
<u>Option</u>
Any idea for mapping?
Mirko Skramusky
February 26, 2013
Hi!
There's an special UnderlineParser in the converter.mediawiki.properties (search for Mediawiki.1504.underline.xmlevent) . This one should correctly replace this tags.
Hope this helps.
Regards
LuizA
February 26, 2013
Hello There,
In a first moment it seems that this can be a convertion problem from the mediawiki, but I'm not sure if this is expected for this kind of convertion from the mediawiki. To obtain a better assistance with this kind of procedure and the UWC I would suggest you to make a contact with the Atlassian Expert AppFusions, that is an expert with UWC cases, you can contact them by the following:
http://www.appfusions.com/
info@appfusions.com
+1-888-516-2890
I hope this helps.
Kind Regards,
LJ.
