Whta we need is some kind of Partial Template to insert in a page. I think this could be solved by a content macro?
Any other suggestions?
You could use the Excerpt Include macro - http://confluence.atlassian.com/display/DOC/Excerpt+Include+Macro
Create a library of excerpts and then use them in whichever pages they are needed.
Andrew.
Thanks, thats something i need too!
But my question was not specific enough. Lets say, i need a table for some vaules, that I want to include on several pages. But i dont want to write the Table from scratch every time.
Some kind of contentsnippet to reuse?
Ah ok, Struggling with this one a bit. If the table and its values are the same you the excerpt include would work for that as well, but if it's just a skeleton table and the values are different then a User Macro (http://confluence.atlassian.com/display/DOC/Writing+User+Macros) might work. For a user macro you could have something like:
## Macro title: My Macro
## Macro has a body: Y or N
## Body processing: Selected body processing option
## Output: Selected output option
## Developed by: My Name
## Date created: dd/mm/yyyy
## Installed by: My Name
## This is an example macro
## @noparams
<table>
<tbody>
<tr>
<th>Year</th>
<th>No. of Widgets</th>
<th>No. of Grommets</th>
</tr>
$body
</tbody>
</table>
where $body would be the text you entered between opening and closing {tablemacro} tags. The problem with this is that what you would have to enter for the body would be the raw HTML, e.g. <tr><td>column1</td></tr><tr><td>column2</td></tr> , which is more timeconsuming and error-prone than just selecting Insert -> Table in the editor .
Another really low tech option if it's just a table skeleton is create a page with different table layouts and copy and paste the one you want each time.
Andrew.
