How can we create a separated Index at same page?
Liara Salerno Valle
June 12, 2020
Does anybody know if it would be possible to create two different Index? one at a collum and a separated one with different topics at the other side?
SMS
June 17, 2020
Hello Liara,
Thank you for bringing this up to us! Happy to help you.
Confluence Cloud includes a Page Index Macro, but I don't believe this is what you are referring to. Take a look at the Page Index Macro documentation to see what that looks like. Is this perhaps the column layout you're referring to?
The other option you mention, which organizes pages by topics, would need you to use labels in order to do this. I would recommend having a read through Use labels to organize your content. There are various macros listed on that page that you can use in order to display content depending on the label (in this case, topic), that you choose.
If this information doesn't help you to get the results you need, would you be able to show me an example of what you're trying to do exactly?
Looking forward to hearing back from you!
Take care,
Shannon
