How do I create a custom Confluence Jira issue macro renderer?
Josh I
October 19, 2022
Confluence has a great built-in macro for inserting a list of Jira issues on a page, but it is not very flexible in how it renders the list. I would like to be able to arbitrarily customize the renderer to be able to show the list in other ways. For example, maybe I want to highlight issues that are past due or I want to show each issue in a more compact "card" style instead of all of the data in a single row.
I looked in the marketplace and didn't find anything that does quite what I want, so I suspect that I'll need to make a custom add-on. Ideally, I would love to start with the code for the built-in Jira macro and just customize the renderer, but I haven't been able to find the code.
Does anyone know where I can get the code for the built-in renderer, or know of an open-sourced add-on I could build on so I don't have to re-invent from scratch? Or is there a marketplace add-on I overlooked that does what I want? Or have ideas for a different strategy for customizing the layout?
Srinatha Tondihal
October 19, 2022
Hi @Josh I ,
Welcome to Atlassian community.
There is already a macro available in market place. You might want to check on the same and it might suite for your requirement.
I hope the info helps. Have a good day!
Srinath T
Josh I
October 19, 2022
Hi @Srinatha Tondihal ,
That macro is close to what I need, but has a couple of problems:
  1. It is only supported on Server (EOL), and I need Cloud.
  2. It doesn't seem to be developed or supported since 2021.
But thanks for the suggestion!
Josh
