How do I use variable data obtained using get-data to filter pages from a local reporter
Surekha Gupta
I am new to confluence and have two sets of pages, one set for 'feature status' and another for 'team status', both are children of a program page. A feature is worked on by many teams, and I want to be able to pull a report on all contributing teams in the feature page.
I want to allow the feature lead to type in the name of a team on feature page, and automatically report on the team's status. I have a live template called 'team rollup' and I tried to copy some concepts from other pages, e.g. using 'replace-and-render' but it does not work. Here is what I have:
h4. Feature XFT1{text-data:XFT1|required=true}{text-data} Status
{replace-and-render}
{replace-item:%Param%}{get-data:XFT1}{replace-item}
{replace-body}
{table-plus:border=0|cellspacing=0|cellpadding=10|sortIcon=true|columnTypes=S,S,S,S,S,S,S,S,I|columnAttributes=,,,style="text-align: center"}
{report-table}{local-reporter:content:children|source=IPOS Infrastructure Feature and XFT status}
{text-filter:data:XFT Name|include=.*'%Param%'*.*}
{natural-sort:data:XFT Status Color|order=descending}
{text-sort:content:title}
{local-reporter}
{report-column:title=Status}{report-info:data:XFT Status Color|render=wiki}{report-column}
{report-column:title=Area}{report-info:data:XFT Area}{report-column}
{report-column:title=XFT}{report-info:content:title|link=true}{report-column}
{report-column:title=OPO}{report-info:data:OPO}{report-column}
{report-empty}This is displayed if no results are returned by the reporter.{report-empty}
{report-table}
{table-plus}
{replace-body}
THis bare minimum without having a variable 'param' works though, and pulls up the report of all teams that have 'Infra' keyword.
{text-filter:data:XFT Name|include=.*Infra*.*}
{local-reporter}
{report-table}
{table-plus}
can someone help me find out how to allow user to input data and then use that data in text-filter within local-reporter?
Kathryn Moye
We have had word from atlassian that if you are using injection when it calls for a regular expression: such as .*%variable%.*, it will not work.
Surekha Gupta
I see conflicting information about whether or not text-filter macro can take injected parameter in various user forums. Can someone confirm whether it can? I am using altassian confluence 2.10.3 and I do not know what version of reporting plugin I am using or how to find this version. Do I need to upgrade my plugin?
Kathryn Moye
This would be very helpful to me too. Here is my example.
<ac:macro ac:name="list-data">
  <ac:parameter ac:name="blank">false</ac:parameter>
  <ac:parameter ac:name="name">DocNumber1</ac:parameter>
  <ac:parameter ac:name="atlassian-macro-output-type">BLOCK</ac:parameter>
  <ac:parameter ac:name="separator">custom</ac:parameter>
  <ac:rich-text-body>
    <ac:macro ac:name="report-block">
      <ac:rich-text-body>
        <ac:macro ac:name="grouping-reporter">
          <ac:parameter ac:name="as">datas</ac:parameter>
          <ac:default-parameter>page:title</ac:default-parameter>
          <ac:rich-text-body>
            <ac:macro ac:name="local-reporter">
              <ac:parameter ac:name="source">OPPIP:Cross Program Products</ac:parameter>
              <ac:default-parameter>page:children</ac:default-parameter>
              <ac:rich-text-body>
                <p>
                  <ac:macro ac:name="text-sort">
                  </ac:macro>
                </p>
              </ac:rich-text-body>
            </ac:macro>
        </ac:macro>
        <ac:macro ac:name="report-body">
          <ac:parameter ac:name="injected">true</ac:parameter>
          <ac:rich-text-body>
            <ac:macro ac:name="list-option">
              <ac:parameter ac:name="value">%grouped:datas%</ac:parameter>
              <ac:rich-text-body> </ac:rich-text-body>
            </ac:macro>
        </ac:macro>
    </ac:macro>
</ac:macro>
  <ac:rich-text-body>
      <ac:rich-text-body>
        <p>
          <ac:macro ac:name="text-filter">
            <ac:parameter ac:name="value">DocNumber1</ac:parameter>
          </ac:macro>
        </p>
    </ac:macro>
      <ac:rich-text-body>
        <p>
          <ac:macro ac:name="report-info">
            <ac:default-parameter>data:APS</ac:default-parameter>
          </ac:macro>
        </p>
        <p> </p>
    </ac:macro>
    <ac:macro ac:name="report-empty">
      <ac:rich-text-body>
        <p>Not Found</p>
    </ac:macro>
</ac:macro>
atlassian, confluence whiteboards, whiteboard templates, template contest, visual collaboration, atlassian learning, confluence community, brainstorming tools, agile planning, team productivity, confluence templates, share your template
Share Your Confluence Whiteboard Template for a Chance to Be Featured in the Product! 🏆
Want to leave your mark on Confluence? One winner will have their whiteboard design added into Confluence for all users to access! This is your chance to showcase your creativity, help others, and gain recognition in the Confluence community.
Share your template today!
