How to Call Confluence Collapsed Node using URL
Yanick Leclerc
July 3, 2017
Using a hyper-link, I want to call a paragraph of content in Confluence that is collapsed using the "Expand" macro, and have that collapsed paragraph appear expanded when called.
I need to call this paragraph from a web page outside of the Confluence site.
I thought I could make this work using anchor links, but that does not seem to work.
That is, in my calling URL, I tried
<a href="https://confluence.ABC_123.com/display/INFO/Some+Page#ZYX_987_LINK>ZYX_987 Page</a>
and in confluence, I modified the Expand macro with the following:
<a name="ZYX_987_LINK"></a>
The above does not work.
Is there a way to call the paragraph that was collapsed in Confluence using the Expand macro and have it appear expanded?
Here is the Confluence macro I'm talking about:
<ac:structured-macro ac:macro-id="..."
ac:name="expand" ac:schema-version="1">
Thank-You
Stephen Deutsch
July 4, 2017
