When I add an expand element on a blank page it's working fine.
When I add a code block to the expand element it's also working fine.
But when I want to do the step above within a table cell, it is not possible to place a code block within an expand element. The code block element is placed below the expand element.
As the previous mentioned feature request was closed, but the relevant part for this question was not handled, the link to the new feature request is here.
Do not think it is solved yet. Still facing this issue
Can confirm this. Have the same problem.
Have same problem
Same problem for me.
This is not ideal, but I found the following workaround (which will only work for specific cases). I used `Layouts`, where code macro inside expand macro works, so I put those on the right, and put 1xN table on the left, however you'd have to do this for every single row separately or hard-code your number of new lines.
I generated an example for for 2x3 table where last column is used for code blocks, here is the screenshot for a preview, hopefully it helps.
Facing the same issue @Florian Storz
