How to add a code block to an expand element within a table cell in new editing experience
Florian S. April 1, 2020
When I add an expand element on a blank page it's working fine.
When I add a code block to the expand element it's also working fine.
But when I want to do the step above within a table cell, it is not possible to place a code block within an expand element. The code block element is placed below the expand element.
Bildschirmfoto 2020-04-01 um 15.53.23.png Bildschirmfoto 2020-04-01 um 15.53.37.png
Florian S. April 29, 2021
As the previous mentioned feature request was closed, but the relevant part for this question was not handled, the link to the new feature request is here.
Florian S. April 8, 2021
Hopefully this will be solved by this feature request
Rakesh Sarangi
May 24, 2022
Do not think it is solved yet. Still facing this issue
Sven Schäfer
June 2, 2022
Can confirm this. Have the same problem.
Julia Rakitina
September 14, 2022
Have same problem
Tazo Lezhava October 9, 2022
Same problem for me.
This is not ideal, but I found the following workaround (which will only work for specific cases). I used `Layouts`, where code macro inside expand macro works, so I put those on the right, and put 1xN table on the left, however you'd have to do this for every single row separately or hard-code your number of new lines.
I generated an example for for 2x3 table where last column is used for code blocks, here is the screenshot for a preview, hopefully it helps.
Rahul Tiwari
November 6, 2023
Facing the same issue @Florian Storz
