How to adjust width and height of iframe to fit with content in it in Confluence On-Demand
Xavier Arques October 4, 2015
I'm developing a Dynamic content macro for Confluence Cloud that returns a dynamic HTML table.
Dynamic Content Macro documentation says "If the size of the macro output content size is dynamic, call AP.resize(w,h) immediately after the DOM of your iframe is loaded."
To retrieve width and height of the content, I found the following code on Internet:
var newheight = document.getElementById(id).contentWindow.document .body.scrollHeight;
var newwidth = document.getElementById(id).contentWindow.document .body.scrollWidth;
But the frame id is generated dynamically and is not accessible through Context Parameter
So, how can I adjust i frame width and height to fit with content inside a dynamic content macro ?
Xavier
Robert Massaioli (Atlassian)
October 4, 2015
I believe that the simplest method is to just use AP.resize() from inside your iFrame. Like so my Sketchfab for Connect addon does.
Robert, Thanks. It works fine if I don't declare parameter height in atlassian-connect.json. I will ask Atlassian to describe AP.resize() API behavior when there is no parameter (https://developer.atlassian.com/static/connect/docs/latest/javascript/module-AP.html)
Xavier Arques October 5, 2015
Documention enhancement required through https://ecosystem.atlassian.net/browse/ACJS-71
Arek Śliwa
January 23, 2017
AP.resize('100%', 'calc(100vh - 160px)');
