How to edit Jira issue create macro?
Narendra Kumar
Hi Team,
I'm using create issue macro in confluence to create new issue in Jira.
There are some fields available on pop-up window when we create a new issue using this macro.
How can I add/remove new field on this pop-up ? Please let me know to update this macro to add new field on pop-up window.
Thanks in advance.
Narendra
Manisha Kharga _Appfire_
July 3, 2020
Hi @Narendra Kumar
We can not edit the Jira issue create macro and add or remove the fields. You can only change the display of Jira field when you are using the search of Jira issue macro.
Mansiha
