How to fix "An error occurred while searching for spaces" when behind reverse proxy?
Emanuel Peters January 3, 2020
I already manually rebuild the index of my server, as described in the support article below.
https://confluence.atlassian.com/confkb/how-to-rebuild-the-content-indexes-from-scratch-on-confluence-server-110035351.html
But, I am still getting an "An error occurred while searching for spaces." when trying to load the "/spacedirectory/view.action" page on my server instance. My server site is behind a reverse proxy, and the server.xml file has been configured properly.
Any Ideas of what I should check next?
Emanuel Peters January 5, 2020
The CDN was causing the problem. I forced the CDN to stop caching objects, and the issue resolved itself. The CDN is currently acting as a reverse proxy for the sole purpose of providing an SSL certificate.
Also, any ideas on why caching my cause this problem?
Andrew Morin
January 3, 2020
Check your base URL to make sure it is set to the correct address?
Emanuel Peters January 4, 2020
Yes. The URL and protocol (https) for the base URL, server.xml, and the CDN acting as a reverse proxy that the server sites behind all match. I'm using AWS CloudFront as a CDN.
