×Hello,
I am able to create Jira epics and Jira issues within confluence. My question however is where is the option when creating a jira issue to link it to a certain jira epic. Below I have attached a link to a confluence youtube video that shows exactly what im looking for. Just wondering if this feature transitioned into a payed application or if it was just taken out for some reason.
https://youtu.be/oEMDz0D4JmE?t=172
thank you
This information is for server
https://confluence.atlassian.com/doc/use-jira-applications-and-confluence-together-427623543.html
For cloud I suggest you an addon
https://marketplace.atlassian.com/apps/1220378/viable-issues?hosting=cloud&tab=overview
Cheers
That addon only allows me to create issues which I can just do with confluence natively. Still no solution for linking these created issues/stories to a specific epic. Maybe I just dont understand how Jira really works. All i want to do is create an epic in confluence and then create subtasks/stories that will be connected to that created epic.
