I do not save the emergency code and I am not able to login with two step verification. can you show me the Steps to recover your Atlassian account.
Hi @Tom Xu ,
You would need to reach out to Atlassian Support and explain your situation there. Usually, they can assist you with login issues.
Good luck!
Tobi
Hi @Tom Xu
Adding to Tomislav's response, you can reference this documentation https://support.atlassian.com/atlassian-account/docs/login-issues-related-to-two-step-verification/#Your-emergency-recovery-key-doesn--x27-t-work-or-you--x27-ve-lost-it , it outlines the steps needed to recover your account after you've misplaced the 2FA device or codes.
