I have a problem when I create a JIRA issues macro.
Deleted user December 14, 2011
When I create a JIRA issues macro appear the following message:
Error on line 76: The element type link must be terminated by the matching end-tag </link>.
class java.io.IOException
Thank you for help me.
Christian Czaia _Decadis AG_
January 15, 2012
I've had the same problem. I our case it was related to the URL
hsuhailah
January 15, 2012
You might be interested to check out this thread - https://answers.atlassian.com/questions/25338/the-element-type-link-must-be-terminated-by-the-matching-end-tag-class-java-io-ioexception-in-the-jiraissues-macro - which has some useful troubleshooting steps.
I would also check if the URL is the valid one. It must be of type XML view of a search as documented in http://confluence.atlassian.com/display/DOC/JIRA+Issues+Macro
-Hanis-
