I have problem with Microsoft EDGE and confluence?
Roberto Lindmark
December 5, 2017
Confluence is not displaying correct on Edge. There is no newsfeed and no top navigation meny. Chrome and Firefox works fine. Can you please check?
Christo Mastoroudes _Adaptavist_
December 5, 2017
On Confluence server if you are using add-ons then it is possible some styling applied might not yet be supported on all browsers. Enabling safe mode will disable all add-ons. Check again to see if it is working. https://confluence.atlassian.com/upm/disabling-and-enabling-add-ons-273875716.html
Ensure that your browser is the latest version. You can have a look at the cloud supported browser list. https://confluence.atlassian.com/cloud/supported-browsers-744721663.html
