Import translation problem - descriptor not matching the zip descriptor
Carina Schmid
August 22, 2023
I have exported about 60 Confluence pages as XLF and have translated it. When uploading only the half of documents were okay. For the rest of 30 documents I got the information, that the descriptor not matching the zip descriptor
Does anybody knows that problem and has a solution?
Thank you!
Sayed Bares [ServiceRocket]
@Carina Schmid welcome to the community!
I suggest raising a support request with the app vendor which in this case should be K15t I believe:
