Increase display result options for JIRA issue macro
Rose Marie Harte October 7, 2013
I use the JIRA issue macro to perform a search in JIRA and display the results in Confluence. My search sorts cards for a Project by Story Points. I would like to display the Story Points column, but this is not currently possible in the JIRA issue macro.
Could this be added?
Thanks!
hsuhailah
October 13, 2013
It should be possible with JIRA issue macro v5.0.3. What is the version of your Confluence and Confluence JIRA Macro Plugin? In "Columns to display" under Display Option, you can add Story Points and the column should be created.
Rose Marie Harte October 20, 2013
I am using Confluence v4.3.6.
I only see JIRA issue macro v5.0.3 for Confluence On Demand 5.2.3 - 5.2.5.
How can I proceed?
