×Hello.
We upgraded our Confluence server to 7.19.3. However, after the upgrade the pages using Plan (Portfolio) and Insight macros are now giving errors throughout. Kindly help!! This is affecting many users.
Thanks.
Kusum.
What is the error message ? Does the application link remain between instances ?
For Advanced Roadmap it's managed by a free app I think.
Do you have the app installed and enabled ?
Same for insight.
Regards
We did have it prior to upgrade, but not seeing it anymore. After installing the advanced roadmap, I am still getting some integration issues (the plan license in Jira seems to be working fine). Also, don't see the Insight plug-in. Is there a known issue with the upgrade?
Thanks.
I'm not aware of such issue, usually when there is an issue with an app during an upgrade, the app is just disabled.
So I installed Advanced Roadmap and the issue got resolved. I am still not sure why:
However, thank you for your response(s). They were helpful.
Thanks.
Kusum.
Hello @Florian Bonniec .
Thank you for your response. The error message says, "Unknown macro: <Macro name>". I got it for Insight and Plan. Other users have reported for some other macros as well. Attaching a couple of screen shots. Also, the macros do not show anymore when trying to add to a Confluence page.
Thanks.
Kusum.
