Is it possible to use a variable in the Jira Issue/Filter macro?
FiveD
August 10, 2016
I'm wondering if there is some workaround or another macro I can use instead of this one.
I want to use a variable ($variablename) in the template so the user needs to fill it out when he creates the page from the template.
Then I want to use this variable in the query in the "JIRA Issue/Filter" macro. But when I try it then the save button is grayed out because it has not resolved the query yet. It's not possible to resolve the query at this stage (when creating the template) because the variable has not been set yet.
The result is that I can't use this template globally because the query differ between confluence spaces.
Another related question. Is it not possible to predefine a variable with a value in the space.
The idea is to have a variable called $jiraProject and for each confluence space it points to different JIRA project key.
And then I can use that key in the query I mention above.
Kristjan
Shashi Kant Sharma
September 18, 2016
Hi Steve / Kristjan,
Did you get any solution to above problem. I too am facing similar problem. I want to fetch some data in multiple tables from JIRA using multiple "JIRA Issue/Filter" in my confluence template. And these resultant tables fetch different kinds of data for the same/ particular JIRA issue Id.  And when this template is used by users to create their documents, every user would need to display data for different JIRA issue id (which belongs to them).
So either users punch in the JIRA issue id inside the JQL everytime, or we can use a variable where user provides their respective JIRA issue id only one time. And the rest all tables would pull data for that issue id at run time.
Nishith Shah
September 8, 2018
Hi Shashi -
Did you get any solution to above problem?
Steve Behnke [DiscoverEquip.com]
August 10, 2016
The only way to accomplish this is with Confluence Blueprints which are created with the Atlassian SDK – They are fairly simple but involve Spring and Maven add-on development, as well as some HTML/javascript.
The built-in template variables will not work I do not believe.
FiveD
August 12, 2016
Thanks Steve.
I might need to start looking at Blueprints smile
Steven F Behnke
August 12, 2016
I'm becoming familiar myself so let me know if you have questions.
Nishith Shah
September 8, 2018
