×we would like to insert jira issue links in the flow charts as shown below.
Can we create something like this in confluence using flow chart or gliffy digrams?
Hi @Rama !
As @Radek Dostál noted, you can add hyperlinks on shapes or text within Gliffy. These can link to anything, including your Jira issues. :) (Mandatory disclaimer that I work for Gliffy!)
Hope this helps.
As far as I know gliffy allows you to add clickables/hyperlinks to different objects.
It doesn't take much to check - https://help.gliffy.com/confluence/Content/GliffyCommon/Linking-shapes.htm
