Jira Issues Macro Resets Max Rows to 20
Corissa Peck
January 8, 2015
I'm using the JIRA Issues macro in my confluence pages. I'd like it to show all issues in the table - not just the first 20. I set the max rows in the display options to blank (or to some large number) and saved.
I noticed, however,  if I go back in and make an unrelated change to the settings of the macro - change my query, for instance - it resets the max rows back to 20.
Is there some way to make that stick to the value I entered before?
Guilherme Nedel [Atlassian]
January 8, 2015
Hello Corissa, in case you are in Confluence pre-5.5 upgrading to a recent version of that application should fix that issue - it has been reported here.
Hope this does the trick.
Corissa Peck
January 8, 2015
Yeah...we're still on 5.4.    Hopefully that will fix it.  Thanks so much!
