×Hi,
we are using a number field in Jira with floating point a value ("1.5") and display the issue in Confluence with the Jira-Issue/Filter Macro. There we get only a rounded value ("2").
Do you have experience with this behaviour? Is there any solution known?
Greetings
Robby
Hi Robby, I took a look at Atlassian's Jira site (jira.atlassian.com) and didn't see anything specific to this issue. Have you tried this on another PC, or in another brower just to eliminate that as an issue? I see you're using 8.2 version of confluence, have you looked at the readme for the later versions to see if this could be an issue that was fixed in the later versions?
Hi Dan,
thanks for your reply. I looked at the release notes and I haven't cound anything about this. I also checked Firefox and Chrome and got the same result. We first saw this issue after upgrading from Confluence 7 to 8.
I think we will raise a support ticket and see what Atlassian tells us about it ;-)
Many thanks
Robby
