×I have many pages in my confluence server instance that use the jira issue macro. When I migrate to cloud all of those macros are broken. I do have a migrated and linked jira instance in the cloud as well. So when I make new jira issue macros they work properly (even when pointing to the same tickets as the macros that do not work).
Is there anything that can be done to make these pages migrate properly? Or is this something that needs to be fixed post migration? Hopefully there is an automated way to fix this?
Hi @dmcleanbkin check out this article on using the Jira Macro Repair utility. Jira Macro Repair
We had to do the same thing after migrating.
Hope that helps.
Hi Dan,
That certainly looks like what I need, Thank you!
I've run it 4 times now and it doesn't seem to be fixing anything.
