×Hey,
I use formatwiki to format the width of the title fields in a table properties report.
Looks like this:
FORMATWIKI("{cell:width=250px}" + T1.'Title' + "{cell}") AS 'Title',
Problem is that that will turn the title into plain text and the hyperlink to the actual case is lost. Any way around this?
Tommy
Hi @Tommy Strømme ,
Please use commas instead of pluses - please check this example from our documentation https://docs.stiltsoft.com/tfac/dc-server/advanced-table-cells-formatting-58426218.html#Advancedtablecellsformatting-Preservinginitialcellformatting
Perfect!
And lightning fast as always I might add :-) Cheers!!
Tommy
This part of the documentation might help you to find your solution.
Otherwise I think you can reach out to Stillstoft support to help you out.
