Hello everyone
I have a requirement where I need to store the documents in the confluence, when I do a context search in the salesforce application,
it has to fetch the documents from the confluence and display them in the salesforce,
Plus, I need some guidance like how can I integrate salesforce to confluence so that I can achieve my above goal
Hi Manjunath SC,
Hope you are doing well.
I'd suggest using Salesforce & Confluence Cloud Publisher.
With the app you will be able to integrate Confluence pages with Salesforce Knowledge base articles.
You can refer to the following documentation on step by step instructions to set up the integration:
Hope it helps.
Best,
Sayed
Hello there!
As I understand, you need to have Confluence content searchable within Salesforce. Currently this is not a native feature of Confluence.
There are, however, third-party apps that may help you with this:
Also, we have an old post here in our Community that deals with a pretty similar request and was recently updated:
Let us hear from you!
