No AWS library when using draw.io plugin
Nick Smith
When I create an AWS diagram from a template via the Confluence draw.io plugin (v6.0.1.0) I don't see any of the AWS icons in the library. If I do the same from draw.io directly I do. How do I solve this?
Nick
David Benson [draw.io]
October 28, 2016
If you click "More Shapes" (bottom left under the shapes libraries), you can select AWS in the more shapes dialog (and tick the remember box so they always appear, if you wish).
Nick Smith
Great, thanks!
