Not able to fetch all spaces using httpRequest
Vinay Patil
May 29, 2024
we are executing one httpRequest with base url (https://vinaypatil88vsp.atlassian.net/wiki/rest/api/search), cql ((type="space" and space.title~"*")),limit (10) and authHeader which is returning the response of spaces &  we are getting only spaces which are custom but, knowledge-based and collaboration spaces are not fetched, I checked cql & tried analyzing and creating various cql still not worked, checked it on community also and readed documentation also but not found the rootcause and solution for it.
"_links": {
"base": "https://vinaypatil88vsp.atlassian.net/wiki",
"context": "/wiki",
"self": "https://vinaypatil88vsp.atlassian.net/wiki/rest/api/search?space.key=T2&cql=type=space%20"
Also I tried with the CQL (type="space" ) but still its giving the same result in its response its returning size=”5” and total Size=”9” and so 4 knowledge-based and collaboration spaces are missing in result array.
Please do provide a potential solution for it.
Thanks and regards,
Matthias Gaiser _K15t_
Hi @Vinay Patil
welcome to the Atlassian Community.
Is there a specific reason why you're using the search endpoint to retrieve the spaces. I'd recommend to use the Get Spaces endpoint which seems to return all the spaces when I try it out.
Be also sure to check if it contains information about paging, e.g. with a next link in the response.
Matthias.
