I have defined a user macro, let's call it {current_version}. I want to use it in a page like this:
Make sure you download version {current_version} of the file, because if you download anything but version {current_version} you get gibberish. See below for a list of URLs:
http://www.example.com/files/file{current_version}
Remember to download {current_version} only. Thanks, bye!
But what happens is, if I use a user macro more than once on a page, it conflates them all and sticks them together, so the above page would render like this:
Make sure you download version 1.1.0 only. Thanks, bye!
All the intervening stuff is skipped! I'm using Confluence 3.4. Is this a bug, or is there a workaround, or what?
Hi Peter,
Make sure you have your user macro set to have 'no body'. I think what it's doing is seeing the first and last as the opening and closing macros, but you want one that doesn't actually have a closing macro.
Hope that helps!
