Problem creating link between jira and bitbucket
Patrick Neary
March 15, 2019
Have an installation where confluence, bitbucket, and Jira have the same server IDs (I was directed to make them all the same to allow our perpetual licenses to work). But now, it seems the duplicate server ids are not allowing me to create application links between Jira and bitbucket. I was able to link confluence and Jira without issue. How do I resolve this problem?
Dave Bosman [Realdolmen]
March 15, 2019
Hi @Patrick Neary
I wonder who told you to use the same server id in all the applications because you will not be able to link 2 applications if they have the same server id.
https://confluence.atlassian.com/kb/setting-up-application-link-results-in-serverid-already-being-used-284368474.html
So, you need to change the server id's to a unique value if you want to do this.
Regards
Dave
