Problem when importing a word document
Shiwen Xu
April 24, 2018
There is result failed when import a word document into confluence
There is a message: "word.import.error.download.file"
Brad Courtney
August 10, 2018
Also on Cloud with the same issue.
Alona Shkolnik
July 31, 2018
Hi, we have same problem, also Cloud. Was there any solution for that?
Lauretha Rura
April 24, 2018
Hi Shiwen,
Are you using Confluence Cloud or Server? If  you're on server, you might want to check the <Confluence-Home>/logs/atlassian-confluence.log file for any errors thrown during the import attempt.
Shiwen Xu
April 24, 2018
I am using the Confluence Cloud,
Where I can find the log files?
Simon
