Problem when starts confluence Application context initialization for 'com.atlassian.confluence.plugins.gadgets' has timed out
Pedro Sousa June 23, 2015
Hey guys
I am change my confluence site to a temporary machine, because I wll update confluence. However, when I try start confluence, this errors locks my installation
Someone helps me?
[]'s
Pedro Sousa
2015-06-23 11:55:50,569 INFO [main] [atlassian.plugin.manager.DefaultPluginManager] init Initialising the plugin system
2015-06-23 11:55:51,099 INFO [main] [atlassian.plugin.manager.DefaultPluginManager] init Plugin system started in 0:00:00.526
2015-06-23 11:55:54,629 INFO [main] [springframework.web.context.ContextLoader] initWebApplicationContext Root WebApplicationContext: initialization started
2015-06-23 11:56:01,083 INFO [main] [com.atlassian.confluence.lifecycle] <init> Loading EhCache cache manager
2015-06-23 11:56:28,165 INFO [main] [springframework.web.context.ContextLoader] initWebApplicationContext Root WebApplicationContext: initialization completed in 33535 ms
2015-06-23 11:56:28,675 INFO [main] [atlassian.plugin.manager.DefaultPluginManager] init Initialising the plugin system
2015-06-23 11:58:34,404 INFO [main] [atlassian.plugin.manager.DefaultPluginManager] notifyPluginDisabled Disabling com.atlassian.confluence.extra.officeconnector
2015-06-23 11:58:34,424 WARN [Timer-1] [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] timeout Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.oauth.serviceprovider, config=osgibundle:/META-INF/spring/*.xml)]
2015-06-23 11:58:34,532 ERROR [Timer-1] [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] fail Unable to create application context for [com.atlassian.gadgets.oauth.serviceprovider], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)] (from bean [&gadgetSpecFactory]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.oauth.serviceprovider' has timed out
    at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454)
    at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50)
    at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105)
    at java.util.TimerThread.mainLoop(Timer.java:512)
    at java.util.TimerThread.run(Timer.java:462)
2015-06-23 11:58:34,539 ERROR [Timer-1] [plugin.osgi.factory.OsgiPlugin] logAndClearOustandingDependencies Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.gadgets.oauth.serviceprovider' with filter (objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)
2015-06-23 11:58:34,541 ERROR [Timer-1] [plugin.osgi.factory.OsgiPlugin] logAndClearOustandingDependencies Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.gadgets.oauth.serviceprovider' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2015-06-23 11:58:34,542 ERROR [Timer-1] [plugin.osgi.factory.OsgiPlugin] onSpringContextFailed Unable to start the Spring context for plugin com.atlassian.gadgets.oauth.serviceprovider
2015-06-23 11:58:34,544 ERROR [Timer-1] [extender.internal.activator.ContextLoaderListener] onOsgiApplicationEvent Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.oauth.serviceprovider, config=osgibundle:/META-INF/spring/*.xml))
2015-06-23 11:58:34,546 WARN [Timer-1] [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] timeout Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.confluence.plugins.gadgets, config=osgibundle:/META-INF/spring/*.xml)]
2015-06-23 11:58:34,547 ERROR [Timer-1] [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] fail Unable to create application context for [com.atlassian.confluence.plugins.gadgets], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.GadgetSpecProvider)] (from bean [&publishedGadgetSpecStore]), Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)] (from bean [&gadgetSpecFactory]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.confluence.plugins.gadgets' has timed out
2015-06-23 11:58:34,548 ERROR [Timer-1] [plugin.osgi.factory.OsgiPlugin] logAndClearOustandingDependencies Never resolved service '&publishedGadgetSpecStore' for plugin 'com.atlassian.confluence.plugins.gadgets' with filter (objectClass=com.atlassian.gadgets.GadgetSpecProvider)
2015-06-23 11:58:34,549 ERROR [Timer-1] [plugin.osgi.factory.OsgiPlugin] logAndClearOustandingDependencies Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.confluence.plugins.gadgets' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory)
2015-06-23 11:58:34,551 ERROR [Timer-1] [plugin.osgi.factory.OsgiPlugin] logAndClearOustandingDependencies Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.confluence.plugins.gadgets' with filter (objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)
2015-06-23 11:58:34,552 ERROR [Timer-1] [plugin.osgi.factory.OsgiPlugin] logAndClearOustandingDependencies Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.confluence.plugins.gadgets' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2015-06-23 11:58:34,553 ERROR [Timer-1] [plugin.osgi.factory.OsgiPlugin] onSpringContextFailed Unable to start the Spring context for plugin com.atlassian.confluence.plugins.gadgets
2015-06-23 11:58:34,555 ERROR [Timer-1] [extender.internal.activator.ContextLoaderListener] onOsgiApplicationEvent Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.confluence.plugins.gadgets, config=osgibundle:/META-INF/spring/*.xml))
2015-06-23 11:58:34,619 WARN [Timer-1] [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] timeout Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.embedded, config=osgibundle:/META-INF/spring/*.xml)]
2015-06-23 11:58:34,622 ERROR [Timer-1] [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] fail Unable to create application context for [com.atlassian.gadgets.embedded], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.view.SecurityTokenFactory)] (from bean [&securityTokenFactory]), Dependency on [(objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)] (from bean [&gadgetSpecFactory])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.embedded' has timed out
2015-06-23 11:58:34,623 ERROR [Timer-1] [plugin.osgi.factory.OsgiPlugin] logAndClearOustandingDependencies Never resolved service '&securityTokenFactory' for plugin 'com.atlassian.gadgets.embedded' with filter (objectClass=com.atlassian.gadgets.view.SecurityTokenFactory)
2015-06-23 11:58:34,624 ERROR [Timer-1] [plugin.osgi.factory.OsgiPlugin] logAndClearOustandingDependencies Never resolved service '&gadgetSpecFactory' for plugin 'com.atlassian.gadgets.embedded' with filter (objectClass=com.atlassian.gadgets.spec.GadgetSpecFactory)
2015-06-23 11:58:34,626 ERROR [Timer-1] [plugin.osgi.factory.OsgiPlugin] onSpringContextFailed Unable to start the Spring context for plugin com.atlassian.gadgets.embedded
2015-06-23 11:58:34,627 ERROR [Timer-1] [extender.internal.activator.ContextLoaderListener] onOsgiApplicationEvent Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.embedded, config=osgibundle:/META-INF/spring/*.xml))
2015-06-23 11:58:34,628 WARN [Timer-1] [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] timeout Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.directory, config=osgibundle:/META-INF/spring/*.xml)]
2015-06-23 11:58:34,629 ERROR [Timer-1] [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] fail Unable to create application context for [com.atlassian.gadgets.directory], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetSpecProvider)] (from bean [&gadgetSpecProviders])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.gadgets.directory' has timed out
2015-06-23 11:58:34,630 ERROR [Timer-1] [plugin.osgi.factory.OsgiPlugin] logAndClearOustandingDependencies Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.gadgets.directory' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
2015-06-23 11:58:34,632 ERROR [Timer-1] [plugin.osgi.factory.OsgiPlugin] logAndClearOustandingDependencies Never resolved service '&gadgetSpecProviders' for plugin 'com.atlassian.gadgets.directory' with filter (objectClass=com.atlassian.gadgets.GadgetSpecProvider)
2015-06-23 11:58:34,633 ERROR [Timer-1] [plugin.osgi.factory.OsgiPlugin] onSpringContextFailed Unable to start the Spring context for plugin com.atlassian.gadgets.directory
2015-06-23 11:58:34,635 ERROR [Timer-1] [extender.internal.activator.ContextLoaderListener] onOsgiApplicationEvent Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.directory, config=osgibundle:/META-INF/spring/*.xml))
2015-06-23 11:58:35,298 ERROR [Spring executor 8] [extender.internal.activator.ContextLoaderListener] onOsgiApplicationEvent Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.confluence.extra.officeconnector, config=osgibundle:/META-INF/spring/*.xml))
java.lang.IllegalStateException: Can only register services while bundle is active or activating.
    at org.apache.felix.framework.Felix.registerService(Felix.java:2730)
    at org.apache.felix.framework.BundleContextImpl.registerService(BundleContextImpl.java:252)
    at org.springframework.osgi.context.support.AbstractOsgiBundleApplicationContext.publishContextAsOsgiServiceIfNecessary(AbstractOsgiBundleApplicationContext.java:344)
    at org.springframework.osgi.context.support.AbstractOsgiBundleApplicationContext.finishRefresh(AbstractOsgiBundleApplicationContext.java:237)
    at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:358)
    at org.springframework.osgi.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
    at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:320)
    at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:132)
    at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
    at java.lang.Thread.run(Thread.java:619)
2015-06-23 11:58:35,329 INFO [main] [atlassian.plugin.manager.DefaultPluginManager] notifyPluginDisabled Disabling com.atlassian.confluence.plugins.gadgets
2015-06-23 11:58:35,331 INFO [main] [atlassian.plugin.manager.DefaultPluginManager] notifyPluginDisabled Disabling com.atlassian.gadgets.directory
2015-06-23 11:58:35,333 INFO [main] [atlassian.plugin.manager.DefaultPluginManager] notifyPluginDisabled Disabling com.atlassian.gadgets.publisher
2015-06-23 11:58:45,364 ERROR [main] [internal.util.concurrent.RunnableTimedExecution] execute Closing runnable for context NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.publisher, config=osgibundle:/META-INF/spring/*.xml) did not finish in 10000ms; consider taking a snapshot and then shutdown the VM in case the thread still hangs
2015-06-23 11:58:45,450 INFO [main] [atlassian.plugin.manager.DefaultPluginManager] notifyPluginDisabled Disabling com.atlassian.gadgets.oauth.serviceprovider
2015-06-23 11:58:45,452 INFO [main] [atlassian.plugin.manager.DefaultPluginManager] notifyPluginDisabled Disabling com.atlassian.oauth.admin
2015-06-23 11:58:55,459 ERROR [main] [internal.util.concurrent.RunnableTimedExecution] execute Closing runnable for context NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.oauth.admin, config=osgibundle:/META-INF/spring/*.xml) did not finish in 10000ms; consider taking a snapshot and then shutdown the VM in case the thread still hangs
2015-06-23 11:59:35,344 ERROR [main] [osgi.container.felix.FelixOsgiContainerManager] doLog ServiceRegistrationImpl: Error ungetting service.
java.lang.NullPointerException
    at com.atlassian.plugins.rest.module.jersey.JerseyRequestFactory.destroy(JerseyRequestFactory.java:61)
    at com.atlassian.plugins.rest.module.jersey.JerseyRequestFactoryServiceFactory.ungetService(JerseyRequestFactoryServiceFactory.java:49)
    at org.springframework.osgi.service.exporter.support.internal.support.PublishingServiceFactory.ungetService(PublishingServiceFactory.java:159)
    at org.apache.felix.framework.ServiceRegistrationImpl.ungetFactoryUnchecked(ServiceRegistrationImpl.java:346)
    at org.apache.felix.framework.ServiceRegistrationImpl.ungetService(ServiceRegistrationImpl.java:259)
    at org.apache.felix.framework.ServiceRegistry.ungetService(ServiceRegistry.java:373)
    at org.apache.felix.framework.ServiceRegistry.ungetServices(ServiceRegistry.java:436)
    at org.apache.felix.framework.Felix.stopBundle(Felix.java:2145)
    at org.apache.felix.framework.BundleImpl.stop(BundleImpl.java:941)
    at org.apache.felix.framework.BundleImpl.stop(BundleImpl.java:928)
    at com.atlassian.plugin.osgi.factory.OsgiPlugin.disableInternal(OsgiPlugin.java:434)
    at com.atlassian.plugin.impl.AbstractPlugin.disable(AbstractPlugin.java:281)
    at com.atlassian.plugin.impl.AbstractDelegatingPlugin.disable(AbstractDelegatingPlugin.java:218)
    at com.atlassian.plugin.manager.DefaultPluginManager.notifyPluginDisabled(DefaultPluginManager.java:1254)
    at com.atlassian.confluence.plugin.ConfluencePluginManager.notifyPluginDisabled(ConfluencePluginManager.java:118)
    at com.atlassian.plugin.manager.DefaultPluginManager.disablePluginInternal(DefaultPluginManager.java:1236)
    at com.atlassian.plugin.manager.DefaultPluginManager.disablePluginWithoutPersisting(DefaultPluginManager.java:1216)
    at com.atlassian.plugin.manager.PluginEnabler.enable(PluginEnabler.java:148)
    at com.atlassian.plugin.manager.DefaultPluginManager.addPlugins(DefaultPluginManager.java:640)
    at com.atlassian.plugin.manager.DefaultPluginManager.init(DefaultPluginManager.java:153)
    at com.atlassian.confluence.plugin.ConfluencePluginManager.init(ConfluencePluginManager.java:185)
    at com.atlassian.confluence.plugin.ConfluencePluginManager.processConfluenceReadyEvent(ConfluencePluginManager.java:298)
    at com.atlassian.confluence.plugin.ConfluencePluginManager.onApplicationEvent(ConfluencePluginManager.java:201)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
    at java.lang.reflect.Method.invoke(Method.java:597)
    at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
    at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
    at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
    at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:106)
    at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
    at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
    at $Proxy10.onApplicationEvent(Unknown Source)
    at org.springframework.context.event.SimpleApplicationEventMulticaster$1.run(SimpleApplicationEventMulticaster.java:78)
    at org.springframework.core.task.SyncTaskExecutor.execute(SyncTaskExecutor.java:49)
    at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:76)
    at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:275)
    at com.atlassian.confluence.event.ConfluenceEventPublisherManager.publish(ConfluenceEventPublisherManager.java:74)
    at com.atlassian.event.legacy.LegacyEventManager.publishEvent(LegacyEventManager.java:36)
    at com.atlassian.confluence.event.ConfluenceEventManager.publishEvent(ConfluenceEventManager.java:40)
    at $Proxy8.publishEvent(Unknown Source)
    at com.atlassian.confluence.upgrade.impl.DefaultUpgradeManager.upgrade(DefaultUpgradeManager.java:140)
    at com.atlassian.confluence.upgrade.UpgradeLauncherServletContextListener.contextInitialized(UpgradeLauncherServletContextListener.java:29)
    at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3972)
    at org.apache.catalina.core.StandardContext.start(StandardContext.java:4467)
    at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
    at org.apache.catalina.core.StandardHost.start(StandardHost.java:785)
    at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
    at org.apache.catalina.core.StandardService.start(StandardService.java:519)
    at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
    at org.apache.catalina.startup.Catalina.start(Catalina.java:581)
    at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
    at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
2015-06-23 11:59:35,349 INFO [main] [atlassian.plugin.manager.DefaultPluginManager] notifyPluginDisabled Disabling com.atlassian.gadgets.embedded
2015-06-23 11:59:35,352 INFO [main] [atlassian.plugin.manager.DefaultPluginManager] notifyPluginDisabled Disabling com.atlassian.gadgets.opensocial
2015-06-23 11:59:35,353 ERROR [Spring executor 14] [extender.internal.activator.ContextLoaderListener] onOsgiApplicationEvent Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.oauth.admin, config=osgibundle:/META-INF/spring/*.xml))
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'applicationProperties': FactoryBean threw exception on object creation; nested exception is java.lang.IllegalStateException: Invalid BundleContext.
    at org.springframework.beans.factory.support.FactoryBeanRegistrySupport$1.run(FactoryBeanRegistrySupport.java:127)
    at java.security.AccessController.doPrivileged(Native Method)
    at org.springframework.beans.factory.support.FactoryBeanRegistrySupport.doGetObjectFromFactoryBean(FactoryBeanRegistrySupport.java:116)
    at org.springframework.beans.factory.support.FactoryBeanRegistrySupport.getObjectFromFactoryBean(FactoryBeanRegistrySupport.java:91)
    at org.springframework.beans.factory.support.AbstractBeanFactory.getObjectForBeanInstance(AbstractBeanFactory.java:1288)
    at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:217)
    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
    at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:425)
    at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:728)
    at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:69)
    at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:355)
Caused by: java.lang.IllegalStateException: Invalid BundleContext.
    at org.apache.felix.framework.BundleContextImpl.checkValidity(BundleContextImpl.java:366)
    at org.apache.felix.framework.BundleContextImpl.addServiceListener(BundleContextImpl.java:201)
    at org.springframework.osgi.util.OsgiListenerUtils.registerListener(OsgiListenerUtils.java:99)
    at org.springframework.osgi.util.OsgiListenerUtils.addSingleServiceListener(OsgiListenerUtils.java:166)
    at org.springframework.osgi.util.OsgiListenerUtils.addSingleServiceListener(OsgiListenerUtils.java:140)
    at org.springframework.osgi.service.importer.support.internal.aop.ServiceDynamicInterceptor.afterPropertiesSet(ServiceDynamicInterceptor.java:464)
    at org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean.createProxy(OsgiServiceProxyFactoryBean.java:215)
    at org.springframework.osgi.service.importer.support.AbstractServiceImporterProxyFactoryBean.getObject(AbstractServiceImporterProxyFactoryBean.java:86)
    at org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean.getObject(OsgiServiceProxyFactoryBean.java:161)
    at org.springframework.beans.factory.support.FactoryBeanRegistrySupport$1.run(FactoryBeanRegistrySupport.java:121)
    ... 17 more
2015-06-23 11:59:35,591 ERROR [Spring executor 19] [extender.internal.activator.ContextLoaderListener] onOsgiApplicationEvent Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.publisher, config=osgibundle:/META-INF/spring/*.xml))
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'permissions#org.springframework.osgi.service.importer.support.OsgiServiceCollectionProxyFactoryBean#0': FactoryBean threw exception on object creation; nested exception is java.lang.IllegalStateException: Invalid BundleContext.
    at org.springframework.osgi.util.OsgiListenerUtils.addServiceListener(OsgiListenerUtils.java:86)
    at org.springframework.osgi.util.OsgiListenerUtils.addServiceListener(OsgiListenerUtils.java:62)
    at org.springframework.osgi.service.importer.support.internal.collection.OsgiServiceCollection.afterPropertiesSet(OsgiServiceCollection.java:272)
    at org.springframework.osgi.service.importer.support.OsgiServiceCollectionProxyFactoryBean.createProxy(OsgiServiceCollectionProxyFactoryBean.java:240)
    at org.springframework.osgi.service.importer.support.OsgiServiceCollectionProxyFactoryBean.getObject(OsgiServiceCollectionProxyFactoryBean.java:188)
    ... 17 more
2015-06-23 11:59:36,236 ERROR [Spring executor 7] [extender.internal.activator.ContextLoaderListener] onOsgiApplicationEvent Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.gadgets.opensocial, config=osgibundle:/META-INF/spring/*.xml))
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'securityTokenFactory_osgiService': Initialization of bean failed; nested exception is java.lang.IllegalStateException: Can only register services while bundle is active or activating.
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:480)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
    at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
    at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
    at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
    at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:423)
Caused by: java.lang.IllegalStateException: Can only register services while bundle is active or activating.
    at org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean.registerService(OsgiServiceFactoryBean.java:310)
    at org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean.registerService(OsgiServiceFactoryBean.java:279)
    at org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean$Executor.registerService(OsgiServiceFactoryBean.java:95)
    at org.springframework.osgi.service.exporter.support.internal.controller.ExporterController.registerService(ExporterController.java:40)
    at org.springframework.osgi.service.dependency.internal.DefaultMandatoryDependencyManager.startExporter(DefaultMandatoryDependencyManager.java:320)
    at org.springframework.osgi.service.dependency.internal.DefaultMandatoryDependencyManager.checkIfExporterShouldStart(DefaultMandatoryDependencyManager.java:261)
    at org.springframework.osgi.service.dependency.internal.DefaultMandatoryDependencyManager.discoverDependentImporterFor(DefaultMandatoryDependencyManager.java:254)
    at org.springframework.osgi.service.dependency.internal.DefaultMandatoryDependencyManager.addServiceExporter(DefaultMandatoryDependencyManager.java:187)
    at org.springframework.osgi.service.dependency.internal.MandatoryDependencyBeanPostProcessor.postProcessAfterInitialization(MandatoryDependencyBeanPostProcessor.java:46)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsAfterInitialization(AbstractAutowireCapableBeanFactory.java:361)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1344)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
    ... 18 more
2015-06-23 11:59:36,243 ERROR [main] [atlassian.plugin.manager.PluginEnabler] enable Unable to start the following plugins due to timeout while waiting for plugin to enable: com.atlassian.confluence.extra.officeconnector,com.atlassian.confluence.plugins.gadgets,com.atlassian.gadgets.directory,com.atlassian.gadgets.publisher,com.atlassian.gadgets.oauth.serviceprovider,com.atlassian.oauth.admin,com.atlassian.gadgets.embedded,com.atlassian.gadgets.opensocial
2015-06-23 11:59:36,251 ERROR [main] [atlassian.confluence.event.ConfluenceEventManager] publishEvent An exception was encountered while processing the event: com.atlassian.confluence.event.events.admin.ConfluenceReadyEvent[source=com.atlassian.confluence.upgrade.impl.DefaultUpgradeManager@2527bdee]
com.atlassian.plugin.event.NotificationException: java.lang.RuntimeException: java.lang.NullPointerException
    at com.atlassian.plugin.event.impl.DefaultPluginEventManager.broadcast(DefaultPluginEventManager.java:92)
    at com.atlassian.plugin.manager.DefaultPluginManager.addPlugins(DefaultPluginManager.java:650)
Caused by: java.lang.RuntimeException: java.lang.NullPointerException
    at com.atlassian.plugin.event.impl.MethodSelectorListenerHandler$1$1.invoke(MethodSelectorListenerHandler.java:63)
    at com.atlassian.event.internal.AsynchronousAbleEventDispatcher$2.run(AsynchronousAbleEventDispatcher.java:60)
    at com.atlassian.event.internal.AsynchronousAbleEventDispatcher$1.execute(AsynchronousAbleEventDispatcher.java:28)
    at com.atlassian.event.internal.AsynchronousAbleEventDispatcher.dispatch(AsynchronousAbleEventDispatcher.java:56)
    at com.atlassian.event.internal.EventPublisherImpl.invokeListeners(EventPublisherImpl.java:145)
    at com.atlassian.event.internal.EventPublisherImpl.publish(EventPublisherImpl.java:67)
    at com.atlassian.plugin.event.impl.DefaultPluginEventManager.broadcast(DefaultPluginEventManager.java:88)
    ... 51 more
Caused by: java.lang.NullPointerException
    at com.google.common.base.Preconditions.checkNotNull(Preconditions.java:186)
    at com.atlassian.plugins.rest.module.OsgiServiceAccessor.<init>(OsgiServiceAccessor.java:34)
    at com.atlassian.plugins.rest.module.ResourceConfigManager.<init>(ResourceConfigManager.java:46)
    at com.atlassian.plugins.rest.module.jersey.JerseyEntityHandler.<init>(JerseyEntityHandler.java:47)
    at com.atlassian.plugins.rest.module.jersey.JerseyRequestFactory.init(JerseyRequestFactory.java:71)
    at com.atlassian.plugins.rest.module.jersey.JerseyRequestFactoryServiceFactory$PluginEnabledListener.init(JerseyRequestFactoryServiceFactory.java:66)
    at com.atlassian.plugin.event.impl.MethodSelectorListenerHandler$1$1.invoke(MethodSelectorListenerHandler.java:49)
    ... 57 more
2015-06-23 11:59:36,262 ERROR [main] [ContainerBase.[Standalone].[localhost].[/]] log Exception sending context initialized event to listener instance of class com.atlassian.confluence.upgrade.UpgradeLauncherServletContextListener
org.springframework.transaction.UnexpectedRollbackException: Transaction rolled back because it has been marked as rollback-only
    at org.springframework.transaction.support.AbstractPlatformTransactionManager.commit(AbstractPlatformTransactionManager.java:672)
    at org.springframework.transaction.interceptor.TransactionAspectSupport.commitTransactionAfterReturning(TransactionAspectSupport.java:321)
    at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:116)
2015-06-23 11:59:37,168 WARN [QuartzScheduler_Worker-2] [search.lucene.tasks.AddDocumentIndexTask] perform Error getting document from searchable
java.lang.IllegalStateException: Cannot retrieve plugin module before it is enabled: PluginModuleHolder[(unknown; not enabled)]
    at com.atlassian.confluence.plugin.module.PluginModuleHolder.getModule(PluginModuleHolder.java:98)
    at com.atlassian.confluence.plugin.descriptor.ExtractorModuleDescriptor.getModule(ExtractorModuleDescriptor.java:101)
    at com.atlassian.confluence.search.lucene.ConfluenceDocumentBuilder.getExtractors(ConfluenceDocumentBuilder.java:94)
    at com.atlassian.confluence.search.lucene.ConfluenceDocumentBuilder.getDocumentBuilder(ConfluenceDocumentBuilder.java:73)
    at com.atlassian.confluence.search.lucene.ConfluenceDocumentBuilder.getDocument(ConfluenceDocumentBuilder.java:102)
    at com.atlassian.confluence.search.lucene.tasks.AddDocumentIndexTask.perform(AddDocumentIndexTask.java:43)
    at com.atlassian.confluence.search.lucene.tasks.UpdateDocumentIndexTask.perform(UpdateDocumentIndexTask.java:40)
    at com.atlassian.confluence.search.lucene.tasks.BulkWriteIndexTask.perform(BulkWriteIndexTask.java:44)
    at com.atlassian.bonnie.LuceneConnection.withWriter(LuceneConnection.java:331)
    at com.atlassian.confluence.search.lucene.tasks.LuceneConnectionBackedIndexTaskPerformer.perform(LuceneConnectionBackedIndexTaskPerformer.java:20)
    at com.atlassian.confluence.search.lucene.DefaultConfluenceIndexManager$BatchUpdateAction.perform(DefaultConfluenceIndexManager.java:356)
    at com.atlassian.bonnie.LuceneConnection.withBatchUpdate(LuceneConnection.java:405)
    at com.atlassian.confluence.search.lucene.DefaultConfluenceIndexManager.processTasks(DefaultConfluenceIndexManager.java:155)
    at com.atlassian.confluence.search.lucene.DefaultConfluenceIndexManager.flushQueue(DefaultConfluenceIndexManager.java:121)
    at $Proxy36.flushQueue(Unknown Source)
    at com.atlassian.confluence.search.lucene.IndexQueueFlusher.executeJob(IndexQueueFlusher.java:29)
    at com.atlassian.confluence.setup.quartz.AbstractClusterAwareQuartzJobBean.surroundJobExecutionWithLogging(AbstractClusterAwareQuartzJobBean.java:63)
    at com.atlassian.confluence.setup.quartz.AbstractClusterAwareQuartzJobBean.executeInternal(AbstractClusterAwareQuartzJobBean.java:46)
    at org.springframework.scheduling.quartz.QuartzJobBean.execute(QuartzJobBean.java:86)
    at org.quartz.core.JobRunShell.run(JobRunShell.java:199)
    at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:549)
2015-06-23 11:59:41,517 INFO [main] [atlassian.confluence.status.SystemErrorInformationLogger] writeToLog
Build Information
baseUrl = http://wiki.petrobras.com.br
home = /ebusiness/shared/confluence/data
buildNumber = 1923
upTime = 3 minutes, 51 seconds
devMode = false
serverId = BKZF-FYG5-LR3A-HWVI
supportEntitlementNumber = SEN-1188730
version = 3.3.1
Server Information
Application Server: Apache Tomcat/6.0.26
Servlet Version:: 2.5
Database Information
Database Dialect: net.sf.hibernate.dialect.Oracle9Dialect
Database URL: java:comp/env/jdbc/confluence
Database Driver Name: null
Database Driver Version: 11.2
Database Name: Oracle
Database  Version: Oracle Database 11g Enterprise Edition Release 11.2.0.3.0 - 64bit Production
With the Partitioning, Real Application Clusters, Automatic Storage Management, OLAP,
Data Mining and Real Application Testing options
Database Latency:14
System Information
favouriteColour = Spindrift
javaRuntime = Java(TM) SE Runtime Environment
operatingSystem = Linux 2.6.18-400.1.1.el5
jvmVersion = 1.0
fileSystemEncoding = UTF-8
javaVm = Java HotSpot(TM) 64-Bit Server VM
javaVendor = Sun Microsystems Inc.
jvmImplementationVersion = 11.2-b01
systemTimezone = America/Sao_Paulo
appServer = Apache Tomcat
tempDirectory = /ebusiness/shared/confluence/confluence-3.3.1-std/temp
date = Tuesday, 23 Jun 2015
jvmInputArguments = -Djava.util.logging.config.file=/ebusiness/shared/confluence/confluence-3.3.1-std/conf/logging.properties -Xms1024m -Xmx4096m -XX:MaxPermSize=512m -XX:+UseParallelOldGC -Djava.awt.headless=true -Dcom.sun.management.jmxremote.port=4123 -Dcom.sun.management.jmxremote.authenticate=false -Dcom.sun.management.jmxremote.ssl=false -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.endorsed.dirs=/ebusiness/shared/confluence/confluence-3.3.1-std/endorsed -Dcatalina.base=/ebusiness/shared/confluence/confluence-3.3.1-std -Dcatalina.home=/ebusiness/shared/confluence/confluence-3.3.1-std -Djava.io.tmpdir=/ebusiness/shared/confluence/confluence-3.3.1-std/temp
time = 11:59:36
jvmVendor = Sun Microsystems Inc.
userName = webadmin
javaVersion = 1.6.0_12
systemLanguage = en
operatingSystemArchitecture = amd64
workingDirectory = /ebusiness/shared/confluence/data/logs
Global Settings
numberOfBreadcrumbAncestors = 999
enableSpaceStyles = false
webdavUsername = null
allowRemoteApi = true
allowThreadedComments = true
nofollowExternalLinks = true
senMissingInLicenseMessageOff = true
backupAttachmentsDaily = false
gzippingResponse = true
sharedMode = false
webdavServerUrl = null
enableQuickNav = true
viewSpaceGoesToSpaceSummary = false
webSudoTimeout = 10
saveable = true
globalDefaultLocale = pt_BR
siteTitle = Confluence
enableWysiwyg = true
maxThumbWidth = 200
defaultSpaceHomepageTitle = Home
indexingLanguage = brazilian
maxThumbHeight = 200
allowCamelCase = false
emailAddressVisibility = email.address.public
defaultEncoding = UTF-8
maxSimultaneousQuickNavRequests = 90
backupDaily = false
denyPublicSignup = true
showContactAdministratorsForm = true
loginManagerSettings = com.atlassian.confluence.setup.settings.beans.LoginManagerSettings@e757105
maxRssItems = 200
almostSupportPeriodEndMessageOff = false
enableDidYouMean = false
enableJavascriptTop = true
externalUserManagement = false
attachmentMaxSize = 104857600
timeZone = time.zone.America.Sao.Paulo
baseUrlAdminMessageOff = false
showSystemInfoIn500Page = false
webdavPassword = null
supportRequestEmail = confluence-autosupportrequests@atlassian.com
allowRemoteApiAnonymous = false
attachmentDataStore = file.system.based.attachments.storage
maxThumbDimensions = 200x200
emailAdminMessageOff = false
disableLogo = false
maxAttachmentsInUI = 5
dailyBackupDateFormatPattern = yyyy_MM_dd
enableOpenSearch = true
xsrfAddComments = true
displayLinkIcons = false
addWildcardsToUserAndGroupSearches = true
useWysiwygByDefault = true
allowTrackbacks = false
webSudoEnabled = false
antiXssMode = true
webdavEnabled = false
siteHomePage = null
dailyBackupFilePrefix = daily-backup-
backupPath = /ebusiness/shared/confluence/data/backups
customContactMessage =
draftSaveInterval = 30000
Usage Info
totalSpaces = 325
localGroups = 1232
localUsers = 35708
globalSpaces = 325
allContent = 385114
indexSize = 294243
personalSpaces = 0
currentContent = 80498
JVM Stats
allocatedHeap = 1989672960
availablePermGen = 450345408
usedMemory = 604893672
totalMemory = 1989672960
freeMemory = 1384779288
maxPermGen = 536870912
usedPermGen = 86525504
freeMemoryInMegabytes = 1320
freeAllocatedHeap = 1384779288
availableHeap = 3212906008
usedMemoryInMegabytes = 576
maxHeap = 3817799680
usedHeap = 604893672
totalMemoryInMegabytes = 1897
Cluster Information
Not clustered.
Enabled Plugins
Add Content Menu Sections (confluence.menu.add, Version: 1.0, Installed: bundled)
Admin Sections (confluence.sections.admin, Version: 1.0, Installed: bundled)
Advanced Macros (confluence.macros.advanced, Version: 1.9B4, Installed: Jul 12, 2012)
Apache HttpClient OSGi bundle (org.apache.httpcomponents.httpclient-4.0, Version: 4.0, Installed: bundled)
Apache HttpCore OSGi bundle (org.apache.httpcomponents.httpcore-4.0, Version: 4.0, Installed: bundled)
Atlassian Gadgets API (com.atlassian.gadgets.atlassian-gadgets-api-2.0.6, Version: 2.0.6, Installed: bundled)
Atlassian Gadgets SPI (com.atlassian.gadgets.atlassian-gadgets-spi-2.0.6, Version: 2.0.6, Installed: bundled)
Atlassian OAuth API (com.atlassian.oauth.atlassian-oauth-api-1.0.12, Version: 1.0.12, Installed: bundled)
Atlassian OAuth Consumer Plugin (com.atlassian.oauth.consumer, Version: 1.0.12, Installed: bundled)
Atlassian OAuth Consumer SAL SPI Implementation (com.atlassian.oauth.consumer.sal, Version: 1.0.12, Installed: bundled)
Atlassian OAuth Consumer SPI (com.atlassian.oauth.atlassian-oauth-consumer-spi-1.0.12, Version: 1.0.12, Installed: bundled)
Atlassian OAuth Service Provider Plugin (com.atlassian.oauth.serviceprovider, Version: 1.0.12, Installed: bundled)
Atlassian OAuth Service Provider SAL SPI Implementation (com.atlassian.oauth.serviceprovider.sal, Version: 1.0.12, Installed: bundled)
Atlassian OAuth Service Provider SPI (com.atlassian.oauth.atlassian-oauth-service-provider-spi-1.0.12, Version: 1.0.12, Installed: bundled)
Atlassian REST - Module Types (com.atlassian.plugins.rest.atlassian-rest-module, Version: 2.0.0, Installed: Feb 16, 2012)
Atlassian Search Results Enhancer (com.atlassian.confluence.plugins.search-resultenhancer, Version: 0.3, Installed: bundled)
Atlassian Template Renderer API (com.atlassian.templaterenderer.api, Version: 1.0.3, Installed: bundled)
Atlassian Template Renderer Velocity 1.6 Plugin (com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin, Version: 1.0.3, Installed: bundled)
Atlassian Templates Import Framework (com.atlassian.confluence.plugins.templates-framework, Version: 0.10, Installed: bundled)
Atlassian Templates: Default Package (com.atlassian.confluence.plugins.templates-default, Version: 0.3, Installed: bundled)
Atlassian UI Plugin (com.atlassian.auiplugin, Version: 3.0.5, Installed: bundled)
Attachment Actions (confluence.sections.attachments, Version: 1.0, Installed: bundled)
Attachment Extractors (com.atlassian.confluence.plugins.attachmentExtractors, Version: 1.1, Installed: bundled)
BND Library (biz.aQute.bndlib-0.0.255, Version: 0.0.255, Installed: bundled)
Basic Macros (confluence.macros.basic, Version: 1.4, Installed: bundled)
Browse Menu Items (confluence.sections.browse, Version: 1.0, Installed: bundled)
Chart Plugin (confluence.extra.chart, Version: 1.15, Installed: Mar 21, 2011)
Classic Left Navigation Theme (com.atlassian.confluence.themes.leftnavigation, Version: 2.12, Installed: bundled)
Clickr Theme (com.atlassian.confluence.themes.clickr, Version: 2.11, Installed: bundled)
Code Macro (confluence.macros.code, Version: 1.5, Installed: bundled)
Comment Action Sections (confluence.comment.action, Version: 1.0, Installed: bundled)
Confluence Atlassian Plugin Repository (confluence.repository.client, Version: 2.1.9, Installed: bundled)
Confluence Attachments Plugin (confluence.extra.attachments, Version: 2.19, Installed: bundled)
Confluence Blogging RPC Plugin (com.atlassian.confluence.plugins.xmlrpc.bloggingrpc, Version: 1.2.4, Installed: bundled)
Confluence Contributors Plugin (com.atlassian.confluence.contributors, Version: 1.2.6, Installed: bundled)
Confluence HTML Macros (confluence.macros.html, Version: 1.8.1, Installed: bundled)
Confluence Legacy Web Resources (legacy.confluence.web.resources, Version: 1.0, Installed: bundled)
Confluence LinkBrowser (com.atlassian.confluence.plugins.linkbrowser, Version: 3.3.1, Installed: bundled)
Confluence PDF Export (com.atlassian.confluence.extra.flyingpdf, Version: 1.9, Installed: May 20, 2015)
Confluence REST API (com.atlassian.confluence.restplugin, Version: 3.3.1, Installed: Sep 25, 2014)
Confluence SAL Plugin (com.atlassian.confluence.plugins.confluence-sal-plugin, Version: 3.3.1, Installed: bundled)
Confluence Thread Dump Plugin (com.atlassian.confluence.plugin.threaddump, Version: 1.3, Installed: bundled)
Confluence Usage Stats (com.atlassian.confluence.ext.usage, Version: 0.13, Installed: bundled)
Content Action Menu Sections (confluence.content.action.menu, Version: 1.0, Installed: bundled)
Content Buttons (confluence.sections.page.temp, Version: 1.0, Installed: bundled)
Content Metadata (confluence.sections.content.metadata, Version: 1.0, Installed: bundled)
Core Extractors (confluence.extractors.core, Version: 1.4, Installed: bundled)
Core Listeners (confluence.listeners.core, Version: 1.3, Installed: bundled)
Core Path Converters (confluence.converters.core, Version: 1.0, Installed: bundled)
Core Startup and Shutdown (confluence.lifecycle.core, Version: 1, Installed: bundled)
Dashboard Actions (com.atlassian.confluence.plugins.dashboard-actions, Version: 1.9, Installed: bundled)
Dashboard Macros (confluence.macros.dashboard, Version: 1.13, Installed: bundled)
Default Macro Metadata Provider (confluence.macro.metadata.provider, Version: 1.0, Installed: bundled)
Default Theme (com.atlassian.confluence.themes.default, Version: 1.0, Installed: bundled)
Did You Mean Index Building Interface (confluence.sections.admin.indexing, Version: 1.0, Installed: bundled)
Documentation Theme (com.atlassian.confluence.plugins.doctheme, Version: 1.2, Installed: bundled)
Dynamic Task List 2 Plugin (confluence.extra.dynamictasklist2, Version: 3.3, Installed: bundled)
Easy Reader Theme (com.atlassian.confluence.plugins.fixedwidth-theme, Version: 3.3.1, Installed: bundled)
Edit Settings Sections (confluence.sections.settings.edit, Version: 1.0, Installed: bundled)
Editor Actions (confluence.editor.actions, Version: 1.0, Installed: bundled)
Follow list resources (confluence.sections.user.follow.list, Version: 1.0, Installed: bundled)
French language pack (confluence.languages.fr_FR, Version: 1.22, Installed: bundled)
Gadgets Plugin SPI (com.atlassian.confluence.plugins.gadgets.spi, Version: 1.1.1, Installed: bundled)
German language pack (confluence.languages.de_DE, Version: 1.17, Installed: bundled)
Global Dashboard Actions (confluence.sections.dashboard.global, Version: 1.0, Installed: bundled)
Global Labels Sections (confluence.sections.labels, Version: 1.0, Installed: bundled)
Google Collections Bundle (com.atlassian.bundles.google-collections-1.0.0.rc1, Version: 1.0.0.rc1, Installed: bundled)
ICU4J (com.atlassian.bundles.icu4j-3.8.0.1, Version: 3.8.0.1, Installed: bundled)
IM Presence NG Plugin (confluence.extra.impresence2, Version: 2.6, Installed: bundled)
Information Macros (confluence.extra.information, Version: 1.3, Installed: bundled)
JDOM DOM Processor (com.springsource.org.jdom-1.0.0, Version: 1.0.0, Installed: bundled)
JIRA Macros (confluence.extra.jira, Version: 2.8.18, Installed: bundled)
JSON Library (com.atlassian.bundles.json-20070829.0.0.1, Version: 20070829.0.0.1, Installed: bundled)
JSR 305 Annotations (com.atlassian.bundles.jsr305-1.0, Version: 1.0, Installed: bundled)
Java Concurrency in Practice Annotations (com.springsource.net.jcip.annotations-1.0.0, Version: 1.0.0, Installed: bundled)
Layout Macros (confluence.extra.layout, Version: 1.5, Installed: bundled)
Live Search Macros (confluence.extra.livesearch, Version: 2.12, Installed: bundled)
Lucene Boosting Strategies (confluence.search.lucene.boosting, Version: 1.0, Installed: bundled)
Mail Page Plugin (com.atlassian.confluence.ext.mailpage, Version: 1.11, Installed: Apr 18, 2013)
News Tabs (confluence.sections.news, Version: 1.0, Installed: bundled)
Page Operations (confluence.sections.page.operations, Version: 1.0, Installed: bundled)
Page Tabs (confluence.search.mappers.lucene, Version: 1.0, Installed: bundled)
Page Tabs (confluence.sections.page, Version: 1.0, Installed: bundled)
Page Tree (com.atlassian.confluence.plugins.pagetree, Version: 1.18, Installed: bundled)
Page View Links (confluence.sections.page.actions, Version: 1.0, Installed: bundled)
Profile Macros (confluence.macros.profile, Version: 1.0, Installed: bundled)
Profile Tabs (confluence.sections.profile, Version: 1.0, Installed: bundled)
ROME, RSS and atOM utilitiEs for Java (rome.rome-1.0, Version: 1.0, Installed: bundled)
Search Web Interface (confluence.sections.admin.generalconfig, Version: 1.0, Installed: bundled)
Search Web Interface (confluence.sections.search.view, Version: 1.0, Installed: bundled)
Shared Application Access Layer API (com.atlassian.sal.sal-api-2.1.0, Version: 2.1.0, Installed: bundled)
Social Bookmarking Plugin (com.atlassian.confluence.plugins.socialbookmarking, Version: 1.3.2, Installed: bundled)
Space Actions Sections (confluence.sections.space.actions, Version: 1.0, Installed: bundled)
Space Admin Sections (confluence.sections.space.admin, Version: 1.0, Installed: bundled)
Space Advanced Sections (confluence.sections.space.advanced, Version: 1.0, Installed: bundled)
Space Browse Sections (confluence.sections.space.browse, Version: 1.0, Installed: bundled)
Space Export Web Interface (confluence.sections.space.export.view, Version: 1.0, Installed: bundled)
Space Item Tabs (confluence.sections.space, Version: 1.0, Installed: bundled)
Space Labels Sections (confluence.sections.space.labels, Version: 1.0, Installed: bundled)
Space Pages Sections (confluence.sections.space.pages, Version: 1.0, Installed: bundled)
System Web Components (confluence.web.components, Version: 1.0, Installed: bundled)
System Web Resources (confluence.web.resources, Version: 1.0, Installed: bundled)
Table of Contents Plugin (org.randombits.confluence.toc, Version: 2.4.11, Installed: bundled)
Tabular Metadata (confluence.extra.masterdetail, Version: 2.9, Installed: bundled)
TinyMCE Editor Plugin (com.atlassian.confluence.tinymceplugin, Version: 3.3.1, Installed: bundled)
UWC Importer Admin Panel (com.atlassian.confluence.plugins.uwc.uwcimporter-adminpanel, Version: 1.2.1, Installed: bundled)
User Administration (confluence.admin.user, Version: 1.0, Installed: bundled)
User Hover Menu Sections (confluence.user.hover.menu, Version: 1.0, Installed: bundled)
User Lister (confluence.extra.userlister, Version: 2.4.5, Installed: bundled)
User Menu Sections (confluence.user.menu.concise, Version: 1.0, Installed: bundled)
User Menu Sections (confluence.user.menu, Version: 1.0, Installed: bundled)
User Status (confluence.userstatus, Version: 1.0, Installed: bundled)
View Changes in Draft (confluence-draft-changes, Version: 1.0, Installed: bundled)
View Profile Web Interface (confluence.sections.profile.view, Version: 1.0, Installed: bundled)
View follow resources (confluence.sections.user.view.follow, Version: 1.0, Installed: bundled)
WebDAV Plugin (confluence.extra.webdav, Version: 2.4, Installed: bundled)
Widget Connector (com.atlassian.confluence.extra.widgetconnector, Version: 1.3.3, Installed: bundled)
Wiki Renderer Components (confluence.renderer.components, Version: 1.0, Installed: bundled)
confluence-imagesearchrenderer-plugin (com.atlassian.confluence.plugins.confluence-imagesearchrenderer-plugin, Version: 1.2, Installed: bundled)
2015-06-23 11:59:42,069 WARN [main] [beans.factory.support.DisposableBeanAdapter] invokeCustomDestroyMethod Invocation of destroy method 'shutdown' failed on bean with name 'pluginManager': java.lang.IllegalStateException: Cannot go from State: STARTING to: SHUTTING_DOWN
2015-06-23 11:59:42,156 INFO [main] [com.atlassian.confluence.lifecycle] contextDestroyed Stopping Confluence
Nic Brough -Adaptavist-
June 23, 2015
Usual culprits are the wrong version of Java in use (although it looks right for your system in this case), or a machine that can't get the resources to run it well enough.
Start with a look through https://confluence.atlassian.com/display/CONFKB/Plugins+are+Disabled+at+Startup+and+Various+Timeout+Errors+Appear+in+the+Logs+After+Startup
I 've cleaned de cache plugins, but the problem persists. select * from BANDANA where BANDANAKEY='plugin.manager.state.Map'; If I update this row, The instance of Confluence will starts in safe mode?
June 23, 2015
And the rest of the things in the document?
I don't update the bandana table. I am afraid to run this query and damage my environment
June 23, 2015
But what about the other things the document has suggested? The bandana table will be ok - in this case, you're setting flags that will be set back later. But if you are that worried, then take a copy of the lines that will be affected, you can put them back if you think there's a problem.
Pedro Sousa June 24, 2015
I do everything that documment suggested and the same error persist
June 25, 2015
Including giving it more memory?
