In the new editor, we are using the excerpt macro to pull info onto a page in a different space.
It appears to work--I can nest the Excerpt macro in the Expand macro--but on the new page, it appears as "Error loading excerpt" and has a scroll bar.
The content does appear if you click the expand arrow, but we don't want the error to appear, or the scroll bar.
Anyone else run across this issue?
I just discovered a workaround for this:
On the main page:
/excerpt (hidden: this can be anywhere on the page)
/expand
/excerpt include (tied to the above excerpt inside the above expand if needed)
If excerpt needed on another page:
/expand
@Megan Stanage I want to make sure I have this correct.
You are adding an excerpt include into an expand macro and getting an error? You should not be able to add the excerpt macro into an expand macro. If you somehow did that is probably the issue.
Not "excerpt include" but "excerpt" - we want to use the content in this expand macro on another page.
The two above screenshots are an expand in an excerpt. Same thing happens if I switch the excerpt into the expand.
@Megan Stanage Thanks for the screenshots. You are on server by the looks of it. My guess is that the content in the expansion is causing the issue. Are you using an additional macro inside the expand? Have you tested using just some basic content like text (This should work)?
We use the Cloud version but the old editor.
The image editor on the new editor is awful and we use lots of screenshots. :(
Using text works fine.
Do you have an additional macro inside the expand?
