Problem with Synchrony
ubnum
March 21, 2019
we have Synchrony not starting and not logging useful information, how understand where is the problem?
Josh Steckler
March 26, 2019
I have found the synchrony logs hard to read, but there is within there some useful information. It's very buried, because it logs a gigantic amount of info to one line of the log file.
If you can find the error line, post it here even if it doesn't look like it provides useful info.
First things to check for you are that the port isn't being used by any other process and that you're not asking for too much memory for the Synchrony process on top of the Confluence process.
