×Hello,
We've a problem when we want to edit the diagram without editing the page.
We could do it before updating the plugin. We have the last version.
Thank you for your help!
This is a bug fix. It was previously possible to directly edit a diagram from a page and publish it without updating any drawio macro in a share draft of the page. It was also possible to save a new diagram version to a shared draft of a page, then go in and start editing the diagram directly without seeing the changes in the shared draft. This causes confusion with versions going out of sync.
We're not sure exactly when this started happening, but we only started to receive reports relatively recently. I'm guessing something changed in synchrony, all the reports are from this year.
The change is now versions saved via direct editing also update the macro in the shared draft of the page. Over time you will see less of this warning. But while you have a state that the two are out of sync on a page, the user will be instructed to edit the other version to get them back into sync.
Hi @Rima BEDJA
I do not know if it is exactly a Confluence problem, you would still have to write to the addon provider
Cheers
