We were trying to embed the content of an .sql file into a confluence page but it didn't work. We dont't receive any error messages and are also unable to find a propper documention of the macro's usage.
Could you help us out with our problem? Are there any other ways to include .txt or .sql file content into a confluence page?
Thanks a lot in advance!
Best regards,
Lukas Gruber
PS: Please find attached a screenshot of the macro we were trying to use.
Thank you for yourl help. I found out it is a third party extension which provides this obviously faulty macro, so I won't be using it.
Best regards!
have you try the {code} macro? You could do something like:
{code:sql} Paste your SQL queries here {code}
For plain text files I recommend you to use the {noformat} macro
