This problem has been fixed in Confluence 6.8.0. Please check it out for the fix
Ok. We have not this version of confluence. We are on 6.4.0 version. I will check that. Thanks for your answer.
Sure, feel free to ping back when you have any questions.
Hi, Chloe.
I unable to replicate the issue on my end, it works fine for me. Do you mind sharing the image URL with us? We will try to replicate using the URL you provide and see if we getting the same behavior.
Hi Suren,
Please find just above the URL :
https://tech.medialog.fr/Images/confluence/Menu installations/Installs-trier-les-elements.png
Sometimes with some images it is working and sometimes Nothing.
Our version of confluence is 6.4.0
Hi here!
We found the problem about images. We found some mistakes on URLs (without "-" between some words etc...)
Best regards,
Have a nice day,
Chloé
