Hi
In the page:
https://confluence.atlassian.com/jirakb/customise-jira-for-test-case-management-191004869.html
in section "5. Custom Fields", there is a table of information.
The table has a column called 'Field Name'. It has three values. However, two (1 and 3) of them are same - "Steps To Complete". I think it's incorrect.
Then, my question what should the field names be?
Thanks!
OK, field 1 should be 'Actual Outcome'.
Please correct the doc.
Can you get the article to work properly? I can´t because there is something wrong with it
ฉันยอมรับคำตอบแล้ว
