I'm new to confluence and learning as I use.
I worked on a document and saved it yesterday. I opened it today and I see that all the formatting has changed. The tables are all over the place. The headings are mixed up.
This was an existing document that I was adding information to.
I've looked in the archives and didn't find anything that could help.
I don't want to make the changes and have the problem recur tomorrow.
Woudl appreciate any help I could get.
Ekta
When you say "document", do you mean an attachment or a Confluence page?
Ok, well, you should be able to simply revert back to a previous version in the history. And maybe use the compare function to find out what changes were made that messed it up.
Well, I had thought of that. But I don't see an option for it. All I see is the Edit option. That's how I'm editing this document and it happens in real time (which is a pain). Have I missed something basic?
On the Tools menu select Page History.
Kay
