Basic URL / Problem after Update auf 6.10.1 from 6.8
Henricus Fluthgraf August 8, 2018
In the Add in section there seems to be a Problem with the URL (see first figure). Whyever, until the update, everything ran well.
As you can see here (figure 2), the URL in the browser ist the same adress like in the Configuration.
SMS
August 9, 2018
Hello Henricus,
Have a look at this article: False Warning About Server Base URL Mismatches on UPM
There are two different causes why this error appears:
  1. There is a known bug in UPM 2.4 which occurs when Confluence is using SSL and doesn't explicitly specify a port in the Server Base URL. Please see  UPM-2339 - Base URL check assumes wrong port for HTTPS CLOSED  for more information.
  2. If you are using SSL and Apache with mod_proxy, the URL redirection is not set in the conf/server.xml
Can you check that and let me know if either resolution listed corrects your issue?
Shannon
Henricus Fluthgraf August 10, 2018
ad 1)2)  as written, until the upgrade vom 6.8 to the latest version, everythin runs without !!! a problem.
SMS
August 10, 2018
Hi Henricus,
I'm not sure I follow your reply.
Could you confirm which version of UPM you're running? The article explains two separate causes and the resolutions for each.
Shannon
Henricus Fluthgraf August 14, 2018
1. UPM has the Version   2.22.14
i can send zou the server xml, but not in this forum.
Henry
SMS
August 14, 2018
Henry,
Thank you for confirming your UPM version.
I'm creating a support ticket for you now, so please check your email in about 5 minutes. You can then submit your server.xml file to that case.
Shannon
