Confiforms Drag and Drop: Index does not update after refreshing the page
Ulrich Brinker May 12, 2022
I have used this example (ConfiForms form with drag and drop and REST API - Vertuna WIKI - TEST) to build a dragable form in Confiforms but unfortunately, the 'Ordernr' doesn't update after refreshing the page.
When changing the order of the rows (by drag and drop) in my form and refreshing afterwards, it will fall back to the previous state. Is it possible that the rows remain in the new order?
Alex Medved _ConfiForms_
Hi @Ulrich Brinker
Welcome to this community!
The question is tagged with cloud and confluence-cloud... I dont think there is a possibility to do what you want in the cloud.
The example you refer to is for server/dc
I have verified that example just now and it works fine for me - what exactly do you have? Let's see what is different
Alex
Ulrich Brinker May 13, 2022
Hey @Alex Medved _ConfiForms_
thanks for your reply.
Since I never worked with Confluence/Confiforms before, I am the excact opposite of an expert. I can access my company's confluence page via browser, when I am connected into their network (VPN) and therefore, thought that it is cloud based, so maybe it is hosted on a server. I honestly don't know. Sorry.
However, I copied the sourcecode given under above mentioned link and get the non-persistant result described. After refreshing the page, the 'Ordernr' gets set back to the order number that I've assigned in the registration form beforehand.
Is it possible that my form saves the new positions (new 'Ordernr') after Drag-and-Dropping them into the new position I need?
Have you changed the code to match your form and page id?
I have changed the formname of the ConfiForms Form Definition from "f1" to "f".
Thats all I changed.
If its relevant, here is the codeblock I am using right now:
<p>form</p>
<ac:structured-macro ac:macro-id="4f63e526-ab65-4a59-8cf7-baff43e3bf29" ac:name="confiform" ac:schema-version="1">
<ac:parameter ac:name="formName">f</ac:parameter>
<ac:rich-text-body>
<p class="auto-cursor-target">
<br/>
</p>
<ac:structured-macro ac:macro-id="6b21d235-3cb2-4f1c-b95c-1a7b09df9071" ac:name="confiform-entry-register" ac:schema-version="1">
<ac:rich-text-body>
<p>
<br/>
</p>
</ac:rich-text-body>
</ac:structured-macro>
<p>
<ac:structured-macro ac:macro-id="5f9ed3ad-449d-4a85-bdb7-d4b92262356c" ac:name="confiform-field-definition" ac:schema-version="1">
<ac:parameter ac:name="fieldName">title</ac:parameter>
<ac:parameter ac:name="fieldLabel">Title</ac:parameter>
<ac:parameter ac:name="type">text</ac:parameter>
</p>
<p>
<ac:structured-macro ac:macro-id="9cd1501b-4577-42ca-9f55-a219b455d126" ac:name="confiform-field-definition" ac:schema-version="1">
<ac:parameter ac:name="fieldName">ordernr</ac:parameter>
<ac:parameter ac:name="fieldLabel">OrderNr</ac:parameter>
<ac:parameter ac:name="type">numberhidden</ac:parameter>
</p>
<ac:structured-macro ac:macro-id="0f086456-1234-4143-bc47-80115ccce664" ac:name="confiform-field-definition-rules" ac:schema-version="1">
<ac:parameter ac:name="fieldName">ordernr=([entry.ordernr]+1)</ac:parameter>
<ac:parameter ac:name="action">Lookup and set value</ac:parameter>
<ac:parameter ac:name="values2">f:12222999</ac:parameter>
<ac:parameter ac:name="values3">ordernr DESC LIMIT 1</ac:parameter>
<p>records</p>
<ac:structured-macro ac:macro-id="4cc00cf5-1070-4a28-824f-b0d7ec842421" ac:name="confiform-table" ac:schema-version="1">
<ac:parameter ac:name="sort">ordernr ASC</ac:parameter>
<ac:rich-text-body>
<p>
<ac:structured-macro ac:macro-id="c3b75cf6-477a-49b2-9f8e-d9267c81dceb" ac:name="confiform-field" ac:schema-version="1">
</p>
<ac:structured-macro ac:macro-id="33d8e448-f88d-4f62-94b7-05ba87601181" ac:name="confiform-field" ac:schema-version="1">
<p>
<br/>
</p>
<br/>
</p>
<ac:structured-macro ac:macro-id="c0a424df-5b20-486c-8045-71b66e9e9814" ac:name="html" ac:schema-version="1">
<ac:plain-text-body><![CDATA[<script>
var fixHelperModified = function(e, tr) {
var $originals = tr.children();
var $helper = tr.clone();
$helper.children().each(function(index) {
AJS.$(this).width($originals.eq(index).width())
return $helper;
updateIndex = function(e, ui) {
AJS.$('td.cf_ordernr', ui.item.parent()).each(function (i) {
AJS.$(this).html(i + 1);
AJS.$(".cf_f_table tbody").find('tr').each(function(i, tr){
var entryId = AJS.$(this).attr('confi-data-id');
AJS.$.ajax({
url: 'https://wiki.vertuna.com/ajax/confiforms/rest/update.action?pageId=12222999&f=f1&q=id:' + entryId + '&fv=ordernr:' + (i+1),
type: "GET",
cache: false,
async: false,
success: function (data) {
AJS.$(".cf_f_table tbody").sortable({
helper: fixHelperModified,
stop: updateIndex
}).disableSelection();
</script>]]></ac:plain-text-body>
<br/>
</p>
The code uses page id 12222999, which is the id of the page where the example is located.
You need to adjust it to match yours
And it also uses form name f1 (in the code)
f=f1
So, if you changed that you need to adjust that as well.
Ulrich Brinker May 15, 2022
Thank you very much, it worked.
I had to change this URL in the source code:
https://xxx.yyy.com/ajax/confiforms/rest/update.action?pageId=1122486467&f=f&q=id:
whereas xxx and yyy is the URL of my institution and 1122486467 the PageID for my specific page.
At the end of the URL I changed "f=f1" to "f=f" because I renamed the "Confiforms form definition Form Name" from "f1" to "f".
Kire Trajkovski May 6, 2025
Hi @Alex Medved _ConfiForms_ ,
Can you help me convert the ConfiForm into html, so I can add a script for drag&drop?
What I see is only a confiForm section with confiForm fields within, but not sure how can I edit the html of the exact same form.
Do you have an HTML macro installed/enabled in your Confluence instance?
Kire Trajkovski May 7, 2025
Yes, but how to translate a confiForm form to confiForm Plain, do I have to learn confiForm from scratch?
I am not sure I understand - what is "confiForm Plain"? What do you want to "translate"?
thanks for the prompt reply. Sorry I though I put the whole context.
My goal is to have drag&drop functionality on the confiForm when I open it with edit and this is applied on the original (source) form. Currently they are build with confiForm form and confiFields not with HTML, but for this (judging on the answer above) I need to have HTML and javascript.
Let me know how can I do this on the easiest way possible.
There is no need to rebuild anything in HTML and javascript. Why?
I am not following...
The configuration shared here earlier is a storage format that you can take and put on your Confluence instance to replicate the example immediately
It contains the configuration of the form and some extra bits that are put inside the HTML macro that enable the drag and drop functionality
Ok, so my current setup with confiForms which is just UI based using confiFields is not working with drag&drop of the rows which for me means a priority of the things in that table.
So, in order to prioritise the work stored in that source table and avoid sequential number, 1,2,3, etc., I would like to simply drag&drop the form while in edit mode and this is saved somehow in the source table.
How can I do this?
If you mean this, yes I have.
@Alex Medved _ConfiForms_ that's a screenshot from my macros
Are you familiar with scripting and HTML?
You will need to a script that is shown in the earlier mentioned in the question page https://wiki.vertuna.com/spaces/TEST/pages/12222999/ConfiForms+form+with+drag+and+drop+and+REST+API
<script>
var fixHelperModified = function(e, tr) { var $originals = tr.children(); var $helper = tr.clone(); $helper.children().each(function(index) { AJS.$(this).width($originals.eq(index).width()) }); return $helper; }, updateIndex = function(e, ui) { AJS.$('td.cf_ordernr span', ui.item.parent()).each(function (i) { var currentIndex = AJS.$(this).html(); if (currentIndex != (i+1)) {              var entryId = AJS.$(this).closest('tr').attr('confi-data-id'); AJS.$.ajax({ url: 'https://wiki.vertuna.com/ajax/confiforms/rest/update.action?pageId='+ AJS.Meta.get('page-id') +'&f=f&q=id:' + entryId + '&fv=ordernr:' + (i+1), type: "GET", async: true, cache: false, success: function (data) { } }); } AJS.$(this).html(i + 1); }); }; AJS.$(".cf_f_table tbody").sortable({ helper: fixHelperModified, stop: updateIndex }); </script>
And adjust it a bit to fit your form (page and fields, and the server (url)) and set up (if you dont have the same as in the example)
Alex
Like Kire Trajkovski likes this
I am familiar with HTML and javascript.
Last questions ...
The URL base url should be my company one?
 - If yes, do I need a specific setup for the ajax call, or it should work by default?
Is the table selector correct, tried the log below and it's returning me 0 elements.
Also does this applies on the source table or on the one in edit mode?
console.log(AJS.$(".cf_f_table tbody"));
- It should be to your server, form name should match
- does your form name is "f"?
I managed to make it working, thanks.
One final question, since I have an edit on a form, when I open the edit mode (confiform Form), the order is not respected on how I sorted the records from the source table by the table view (confiform Table) which I made sortable.
It seems that it does only fetch + ORDER BY "StackRank" DESC.
Any clues how to fix this so the same order is applied in the edit form below?
Form's admin UI always sorts data by "created DESC". It has no idea about your "stack rank"
Create a TableView over your data and set it to be sorted by the stack rank
Will try that, thanks.
In the meantime, is there a way to make the numbering update with the position like it's on the demo you've shared?
Also, the order is not saved, after a page reload, it resets to default, I guess 'created ASC'. This is why I have the ajax call right, but it's not saved for some reason. Any ideas?
The demo we have saves the order correctly.
Kire Trajkovski May 8, 2025
I just revisited the demo. It's not saving the order permanently, it returns "302 Found". After I refresh the page the order is back to defaults, not in the order I created.But for me there is no ajax call happening and also no console error. Any clues?
I fixed the Ajax call and it's returning 200 OK, but still not permanently keeping the order. Can you just confirm that the reordering should be permanent change so I don'w waste my time implementing it if that's not the case?
Of course it is permanent, as this is exactly what the API calls do - they persist the data to the form.
What do you have now?
So here is what it's working:
- sortable
- dynamic order number just like on the demo
Not working:
- keeping the order permanently, after reorder and reload the page the order is gone even though the ajax call is 200 OK
HOW do you have it configured?  Could you share your configuration?
Otherwise I cannot help you - the demo on our wiki works, the code I have shared with you - works... What code and the form configuration do you have - I have no idea
Kire Trajkovski May 9, 2025
I am not sure what you mean by "configured"? Do you mean the form config or the JS code? If form, how can I share all that here?
The storage format of the page or at least a screenshot from the editor (where I can see the form definition and field definitions) with full code you have in the HTML macro
Kire Trajkovski May 12, 2025
Here is a screenshot (see below) from the form config only from the Registration View (ConfiForm) and below I am sharing the whole JS code.
This is what I present on the page, the visuals are shared in the previous attachment in this thread above:
- Registration View (ConfiForm)
       - this is only a button "Request" to popup the form
- Table VIew
       - a table view on the records created by the first form
- Form Definition
       - Edit mode for the form
<script>
console.log("Page ID: " + AJS.Meta.get('page-id'));
    return $helper;
    AJS.$('td.cf_StackRank', ui.item.parent()).each(function (i) {
          AJS.$.ajax({
      url: 'https://DOMAIN.com/ajax/confiforms/rest/update.action?pageId='+ AJS.Meta.get('page-id') +'&fKiCfeatureintake=&q=id:' + entryId + '&fv=StackRank:' + (i+1),
      type: "GET",
            async: true,
            cache: false,
console.log($(".cf_KiCfeatureintake_table tbody"));
$(".cf_KiCfeatureintake_table tbody").sortable({
    stop: updateIndex
</script>
Please verify the solution on the demo once again, after reorder the elements are not safe, I hope I am not testing this with another guy someplace else simultaneously :)
Cheers
Check this
This part in particular
You give this "fKiCfeatureintake=" as a form name
oh, nice catch, I missed the "=" between the f and the form name, this is the corrected URL, but still doesn't work even though the response is 200 OK:
url: 'https://DOMAIN.com/ajax/confiforms/rest/update.action?pageId='+ AJS.Meta.get('page-id') +'&f=KiCfeatureintake&q=id:' + entryId + '&fv=StackRank:' + (i+1),
Try making it to use async = false mode to tregger the update requests
async: false,
I tried also that, also not working:
    stop: updateIndex,
    async: false
Not what I have said... here is the complete code
<script type="text/javascript">
AJS.toInit(function () {
var fixHelperModified = function (e, tr) {
$helper.children().each(function (index) {
return $helper;
updateIndex = function (e, ui) {
if (currentIndex !== (i + 1)) {
AJS.$.ajax({
url: 'https://CONFLUENCE_URL/ajax/confiforms/rest/update.action?pageId=' + AJS.Meta.get('page-id') + '&f=KiCfeatureintake&q=id:' + entryId + '&fv=StackRank:' + (i + 1),
type: "GET",
async: false,
cache: false,
stop: updateIndex
</script>
OK, I misunderstood, thanks.
I copy/pasted the whole text, changed the HOST name and still not working. Checked the console, the log is fine, printing the pageID and the tbody correctly.
Kire Trajkovski May 14, 2025
Any thoughts on why this is still not working @Alex Medved _ConfiForms_ ?
The code you have shared -> take a look at this video - persists the changes...
Kire Trajkovski May 15, 2025
Thanks Alex,
I am noticing different behaviour on different browsers. Can you please share the browser and the version you use?
I will try, verify and advice the team to use that specific browser for now until I find more common solution.
