I have a confiform that has a currency filed. It seems like it is defaulting currency symbol to £ instead of $.
I have the default set to $ in the form field definition. All it does is places the $ in front of £
Is there another place I should look to see if the default is configured correctly? I think this started after recently updating the plugin.
Alex with Vertuna was able to help me with this one. Issue resolved.
Hi, Tim.
Would you please share the solution. We have a similar issue. Thx.
If I remember correctly, all I had to do was set the formatting pattern.
I just inserted this ###,###.### in the field it displayed the correct currency.
You can learn more about the formatting here: https://docs.oracle.com/javase/tutorial/i18n/format/decimalFormat.html
