Confiforms Issue: Currency default not correct
Tim Oldendorf
September 24, 2018
I have a confiform that has a currency filed. It seems like it is defaulting currency symbol to £ instead of $.
I have the default set to $ in the form field definition. All it does is places the $ in front of £
Is there another place I should look to see if the default is configured correctly? I think this started after recently updating the plugin.
Tim Oldendorf
September 24, 2018
Alex with Vertuna was able to help me with this one. Issue resolved.
Maxim Grouchevoi November 2, 2018
Hi, Tim.
Would you please share the solution. We have a similar issue. Thx.
Tim Oldendorf
November 2, 2018
If I remember correctly, all I had to do was set the formatting pattern.
I just inserted this ###,###.### in the field it displayed the correct currency.
You can learn more about the formatting here: https://docs.oracle.com/javase/tutorial/i18n/format/decimalFormat.html
Like # people like this
