Confluence Questions Does Not Render Code Block Macro
CharlesM February 16, 2018
We are testing Confluence Questions. When we insert the code block macro into a question, it renders correctly in the Preview. But when we save, all rendering disappears. Any ideas why this might be happening?
We're that perhaps the content is either meant to render that way in Questions or it may be an issue with the macro.
That's odd since in the macro preview I see it rendered correctly:
This is how (non)renders in Questions:
So Questions seems not to use the native Confluence code block macro correctly.
Ideas?
Shannon S
February 16, 2018
Hi Charles,
It seems like you've run into this bug that I reported:
Can you confirm your Confluence and Questions versions so I can update the bug with your information?
Please feel free to watch that bug, vote on it to help show the number of affected users, and comment there with your findings.
Thank you!
Shannon
Thanks, Shannon. Will do.
